Observer jacklsw86
Select default ISE version to launch
I notice that whenever I open ISE by double clicking the ISE project file, it will open the ISE version that I install the latest. I want to change it back to previous version that I installed but I can't seem to find the method to do so. Anyone of you knows how can I change the default ISE version when launching from the project file? Eg. I got 14.1 then i installed 14.2 but I want it to open by default in 14.1. Thanks.
Jack
Professor
Professor
Re: Select default ISE version to launch
In Windows 7, right click on the project file icon, then select "Choose default program..."
This should bring up a list of applications that Windows thinks appropriate.  If you don't
see the version of ISE you want, you may need to browse to its executable.
-- Gabor
-- Gabor
Professor
Professor
What Operating system are you running?  The answer is different for each OS.
-- Gabor
-- Gabor
Observer jacklsw86
i'm using windows 7 64-bits machine.
Professor
Professor
-- Gabor
-- Gabor
Observer jacklsw86
oh, silly me. how can i forget about this common feature in windows :(
*saw the project file points to settings64.bat so i was trying to figure out how do i change my default ISE version there. wasn't aware the solution was so much simpler.
thanks gabor. :)
