Seperate flow for Synthesis+P&R for a ceratain hierarchy in design -> is this possible?
Hi All,
I have some hierarchy in my design with timing violations.
How could I make this hierarchy as a Black Box, so it would be still an inherent part of the physical flow (P&R), yet be synthesized separately?
Thank you!
Re: Seperate flow for Synthesis+P&R for a ceratain hierarchy in design -> is this possible?
Hi @ldm.eth ,
Are you looking for incremental compile flow?
Please check this AR#:
https://www.xilinx.com/support/answers/57853.html
Raj
回复: Seperate flow for Synthesis+P&R for a ceratain hierarchy in design -> is this possible?
You can select this piece of hierarchy in Sources window and select "Set As Out-Of-Context for Synthesis" option in the right-click menu.
For more description, please have a look at UG901, pg23, section "Setting a Bottom-Up Out-of-Context Flow".
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug901-vivado-synthesis.pdf
Hi, @ldm.eth ,
You can also consider the PR flow described in UG909.
