Setting constraints for submodules
I am creating a design that incorporates a number of submodules into a top level design.  Several of the submodules have their own constraints.  I included these in the constraints file for the top level design but when I implement the design I get critical warnings saying that no valid object is found for the the pins and ports that I am setting constraints for.  Do I need to create seperate IP blocks for these submodules first and then incorporate them into my design rather than just intatiating in the top level vhdl file?  Or is there another way to constrain a submodule?
example of the warning message:
[Vivado 12-4739] set_max_delay:No valid object(s) found for '-from [get_pins u_tx_async_fifo/FifoMem_reg_*/*/CLK]'.
Re: Setting constraints for submodules
Hi @stephen.lindeman,
Please go through UG 903 , page 71 onwards - IP and sub-module constraining with XDC. This will help you out.
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_1/ug903-vivado-using-constraints.pdf
hemangd
Teacher drjohnsmith
dont knwo you rlanguage,
but if its VHDL , entities dont have pins,
so cant be referenced like this.
Why do you want to constrain clocks in sub modules,
     I assume these clocks must come down to the sub modules, form the top architecture, which  does have pins
            the timming constraints for the top level clocks are propergated down to lower levels.
Scholar markcurry
Stephen,
You're looking for "Scoped constraints" or a "Scoped XDC" file.  Search these forums for those terms - it's exactly what you're looking for.
If you're still having issues, come back here - I can give more specific advice.
Mark
hemangd
