Setting up Vivado LSF queue
Hi, Could somebody help me figure out how to get LSF setup in Vivado running on Linux servers in my company?    I need to work with my admins to figure this out, but I am not sure what questions to ask them.   I showed them the setup screen that showed a bsub command but they told me to try using another command we use internally as a wrapper to bsub, but that didn't work.
Is there something I can do in the terminal to determine what command needs to be in the LSF command line text box in the LSF setup in Vivado?
Tim
Re: Setting up Vivado LSF queue
Hi @tim_severance
Refer the below link, Appendix A for information on this:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_2/ug904-vivado-implementation.pdf
Hope this helps.
Rohit
Rohit
