Visitor wk.open
Signal <switch> and <led> not routed in the top level design of a partial reconfiguration
Environment: ISE 14.6, PlanAhead 14.6 with Partial Reconfiguration enabled.
Board: Zedboard
Reference Tutorial: UG743
I'm implementing a very simple partial reconfiguration design with a top.v and two modules, an "adder" and a "multiplier".
Top.v
INPUT: SWITCH[7:0], OUTPUT LED[6:0]
The "adder" will use SWITCH[3:0] as the inputs and display result to LED[2:0].
The "multiplier" will use SWITCH[7:4] as the inputs and display result to LED[6:3];
Translated into Verilog code will be:
module top(
    input  [7:0]	switch,
    output [6:0]  led);
    // instantiate reconfigurable module BRAM
    twobit_adder U1_RP_Adder (
      .a    (switch[1:0]),
      .b    (switch[3:2]),
      .z    (led[1:0]),
      .cout (led[2])
    // instantiate reconfigurable module counter
    twobit_blank_multiplier U2_RP_Multi (
      .a    (switch[5:4]),
      .b    (switch[7:6]),
      .z    (led[6:3])
endmodule
 And I also added an UCF to the top file as the following:
# PlanAhead Generated physical constraints
NET "led[6]" LOC = U14;
NET "led[5]" LOC = U19;
NET "led[4]" LOC = W22;
NET "led[3]" LOC = V22;
NET "led[2]" LOC = U22;
NET "led[1]" LOC = T21;
NET "led[0]" LOC = T22;
# PlanAhead Generated IO constraints
NET "led[6]" IOSTANDARD = LVCMOS18;
NET "led[5]" IOSTANDARD = LVCMOS18;
NET "led[4]" IOSTANDARD = LVCMOS18;
NET "led[3]" IOSTANDARD = LVCMOS18;
NET "led[2]" IOSTANDARD = LVCMOS18;
NET "led[1]" IOSTANDARD = LVCMOS18;
NET "led[0]" IOSTANDARD = LVCMOS18;
NET "switch[7]" IOSTANDARD = LVCMOS18;
NET "switch[6]" IOSTANDARD = LVCMOS18;
NET "switch[5]" IOSTANDARD = LVCMOS18;
NET "switch[4]" IOSTANDARD = LVCMOS18;
NET "switch[3]" IOSTANDARD = LVCMOS18;
NET "switch[2]" IOSTANDARD = LVCMOS18;
NET "switch[1]" IOSTANDARD = LVCMOS18;
NET "switch[0]" IOSTANDARD = LVCMOS18;
NET "switch[7]" LOC = M15;
NET "switch[6]" LOC = H17;
NET "switch[5]" LOC = H18;
NET "switch[4]" LOC = H19;
NET "switch[3]" LOC = F21;
NET "switch[2]" LOC = H22;
NET "switch[1]" LOC = G22;
NET "switch[0]" LOC = F22;
 In PlanAhead, I created a new project with partial reconfiguration enabled and set top.ngc and top.ucf as the top file. And I also set two partitions according to the modules defined in top.v and gave them .ngc files w/o any other .ucf files.
But when I ran "Run Implementation" there were warnings shown:
WARNING:Par:289 - The signal switch[7] has no driver. PAR will not attempt to route this signal.
WARNING:Par:289 - The signal switch[6] has no driver. PAR will not attempt to route this signal.
WARNING:Par:289 - The signal switch[5] has no driver. PAR will not attempt to route this signal.
WARNING:Par:289 - The signal switch[4] has no driver. PAR will not attempt to route this signal.
WARNING:Par:289 - The signal switch[3] has no driver. PAR will not attempt to route this signal.
WARNING:Par:289 - The signal switch[2] has no driver. PAR will not attempt to route this signal.
WARNING:Par:289 - The signal switch[1] has no driver. PAR will not attempt to route this signal.
WARNING:Par:289 - The signal switch[0] has no driver. PAR will not attempt to route this signal.
WARNING:Par:288 - The signal led[6] has no load. PAR will not attempt to route this signal.
WARNING:Par:288 - The signal led[5] has no load. PAR will not attempt to route this signal.
WARNING:Par:288 - The signal led[4] has no load. PAR will not attempt to route this signal.
WARNING:Par:288 - The signal led[3] has no load. PAR will not attempt to route this signal.
WARNING:Par:288 - The signal led[2] has no load. PAR will not attempt to route this signal.
WARNING:Par:288 - The signal led[1] has no load. PAR will not attempt to route this signal.
WARNING:Par:288 - The signal led[0] has no load. PAR will not attempt to route this signal
I simply ignored the warnings and ran "Promoted" and "Generate Bitstream", but in "Generate Bitstream" those warnings became errors:
ERROR:PhysDesignRules:10 - The network <switch[7]> is completely unrouted.
ERROR:PhysDesignRules:10 - The network <switch[6]> is completely unrouted.
ERROR:PhysDesignRules:10 - The network <switch[5]> is completely unrouted.
ERROR:PhysDesignRules:10 - The network <switch[4]> is completely unrouted.
ERROR:PhysDesignRules:10 - The network <switch[3]> is completely unrouted.
ERROR:PhysDesignRules:10 - The network <switch[2]> is completely unrouted.
ERROR:PhysDesignRules:10 - The network <switch[1]> is completely unrouted.
ERROR:PhysDesignRules:10 - The network <switch[0]> is completely unrouted.
 It looks like I didn't route <switch> and <led> properly, but in top.v I declared the assignments so I am confused where I went wrong.
If anyone can help me with this problem, it will be a boost to my study of partial reconfiguration on Zedboard. Thank you in advance!
Mentor hgleamon1
Mentor
Re: Signal <switch> and <led> not routed in the top level design of a partial reconfiguration
@wk.open wrote:
And also, do these two critical warnings have anything to do with the connection problem?
These two warnings exist when I created the PlanAhead project and imported top.v into the project.
Yes. Directly. It means that the tools cannot find your subcomponents. Subsequently, with no subcomponents, there are no connections, hence the top level failure.
You need to check that the subcomponents are included in the design directory or, if you are instantiating netlists (but I don't think you are), the relevant .NGC files should be in the design directory.
"That which we must learn to do, we learn by doing." - Aristotle
Mentor hgleamon1
Mentor
Can you post your adder and multiplier submodules, so we can see what happens to the top level nets at the lower levels?
It appears that the top level nets are not connected to anything, which suggests some issues with your hierarchical implementation.
Howard
Visitor wk.open
Sure. Here is the adder:
entity twobit_adder is
	port( a, b : in STD_LOGIC_VECTOR(1 downto 0);
	z : out STD_LOGIC_VECTOR(1 downto 0);
	cout : out STD_LOGIC );
end twobit_adder;
architecture MY_STRUCTURE of twobit_adder is
component FULL_ADDER
    port( x, y, cin : in STD_LOGIC;
    sum, cout : out STD_LOGIC );
end component;
signal c0, c1 : STD_LOGIC;
begin
    c0 <= '0';
    b_adder0: FULL_ADDER port map (a(0), b(0), c0, z(0), c1);
    b_adder1: FULL_ADDER port map (a(1), b(1), c1, z(1), cout);
END MY_STRUCTURE;
 FYI the full adder module is:
entity full_adder is
	port(x, y, cin: in std_logic;
	sum, cout: out std_logic);
end full_adder;
architecture my_dataflow of full_adder is
begin
	sum <= (x xor y) xor cin;
	cout <= (x and y) or (x and cin) or (y and cin);
end my_dataflow;
 And the multiplier module is:
entity twobit_multiplier is
    Port ( a : in  STD_LOGIC_VECTOR (1 downto 0);
           b : in  STD_LOGIC_VECTOR (1 downto 0);
           z : out  STD_LOGIC_VECTOR (3 downto 0));
end twobit_multiplier;
architecture my_dataflow of twobit_multiplier is
begin
	z <= a * b;
end my_dataflow;
 In order to prevent ISE from trimming my ports, I add the following SAVE constrains to the .ucf file of my adder and multiplier as PlanAhead doesn't allow IOBUF in partial reconfiguration partitions.
NET "a*" S;
NET "b*" S;
NET "z*" S;
NET "cout" S;
 I believe my adder and multiplier are working fine as I have tested them separately on Zedboard with ports directly connected to switches and LEDs. So I believe it's the io buffer thing which drove me crazy these days.
Thank you!
Visitor wk.open
And besides of that, I turned off auto iobuf option in design strategy for adder and multiplier but NOT for the top module.
Visitor wk.open
Visitor wk.open
PlanAhead showed some warning about the constraint matching when "Run Implementation" was run. Here is an example:
[ConstraintSystem 119] Constraint <NET "led[6]" LOC = U14;> [config_1.ucf(13)]: This constraint cannot be distributed from the design objects matching 'NET "led[6]"' because those design objects do not contain or drive any instances of the correct type.
Same warning for led[5] 4 3 2 1 0 and switch[7] 6  5 ... 0
Mentor hgleamon1
Mentor
Community Manager
Community Manager
The two critical warnings are important. They are trying to convey that both these modules have been taken a black boxes and they can be resolved.
Please check on how you are adding your source files.
Visitor wk.open
Thank you hgleamon1!
I created a new PlanAhead project and added the whole directory of top module into the project and those two critical warnings never showed up again. And I could successfully generate bit files without any problem :)
Visitor wk.open
Thank you siktap. Those warnings are critical to solve my problem, now I can run my implementation w/o any problem.
Visitor xertian
hi,wk.open
i am now running with the same critical warning as u described above .icant quite .understand . how u solved this .can u describe more clearly ?
thks
