Visitor net.worker
Slice type report
how can I produce a report in which I can see exactly how many of the different slice types (SLICEX, SLICEL, SLICEM) are occupied by my design? In the MAP report, only the sum of all slice types is reported. This is on Spartan 6 with ISE.
The background of my question is the following:
  • There is one large address multiplexer structure in all the designs I have at the moment. It is a frequent source of timing worries as it has 15 logic levels and is constrained to 125 MHz, but cannot really be touched at this stage.
  • A new central core block uses lots of wide combinatorial logic (dynamic counters with compares).
  • Now I see that the address multiplexer will not come out with clean timing, although the new core has (almost) no violations.
  • My guessing is that the new core uses more SLICELs than the previous cores, which would otherwise help implementing the wide mux. Does this make sense?
So, it would be nice to get the slice type report to find out what the problem really might be. But I might also start thinking about how to improve that legacy mux...
Florian
Community Manager
Community Manager
Re: Slice type report
An easier way would be to import your ncd with Planahead or Vivado. and check the utilization. Please see the highlighted picture
Community Manager
Community Manager
Visitor net.worker
Nice tip. I got the resource estimation out of PlanAhead.
My problem was on the other hand solved in the meantime by SmartXPlorer with synthesis variation. :-)
Community Manager
Community Manager
Thanks. Glad that smartxplorer helped. :)
Community Manager
Community Manager
