SmartXplorer Problems - Looking for a Workaround
All:
     I'm doing some maintenance work on an older project that uses ISE 13.2.  Timing Closure has always been an issue so I have to use SmartXplorer.  My company, a while back, upgraded out servers to newer version of software.  Our scheduler is called "PBS Torgue".  The operating system supported are RedHat 6 and RedHat 5.
     My installed version of SmartXplorer doesn't support our new scheduler.  The error message I get says it's looking for a path to the Sun Grid tools which has been obsoleted by our system Admins.  Skipping the configuration check doesn't work since SmartXplorer can't spawn any jobs (can't find qmon).
     Does anyone know of a workaround for this issue?  I'm guessing the issue is with "PBS Torque" .  The error message I get is listed below.
ERROR: Could not find qmon. Please make sure Sun Grid Engine tools are in your PATH.
Please set this env XIL_SX_SKIP_CLUSTER_CONFIG_CHECK if you want to bypass this error.
Re: SmartXplorer Problems - Looking for a Workaround
@marvinscheinbart,
Did you try setting the env variable mentioned in error message?
--Syed
Syed:
     I spoke to my system administrator about this issue.  The error is not being able to find the function qmon.  This program is part of the Sun Grid tools which are no longer supported by our system.  The Sun Grid tools have been replaced with PBS Torque which uses the command qsub to dispatch jobs.
     Setting XIL_SX_SKIP_CLUSTER_CONFIG_CHECK would not be of any help.
        Marv
