SmartXplorer Translate (ngdbuild) options
Hi all,
with (ISE) SmartXplorer it is possible to run different MAP/PAR strategies in parallel. After the synthesis, smartxplorer applies a Translate (ngdbuild) and the result of translation is used for all MAP/PAR strategies.
Is it possible to give smartXplorer some options for the ngdbuild process? In my case, I want to use the
-bm <my_bram_structure.bmm>
option (which is a ngdbuild option if i call ngdbuild directly). How to do this with smartyplorer?
Best regards!
Re: SmartXplorer Translate (ngdbuild) options
Hi @s9445855
You can give seperate command for translate (ngdbuild) and pass the required switches before using the smartxplorer command.
Deepika.
Deepika.
Hi @s9445855
Have you tried specifying this switch in Translate properties?
Deepika.
Deepika.
Hi vemulad,
Thanks for your response. I suppose you mean a switch in a GUI?
I am working on command line and tried to add the -bm directly to the smartyplorer call. This was not successful.
I need a solution for a command line call of smartxplorer.
Best regards.
Hi @s9445855
Deepika.
Deepika.
You are right. I was not aware that smartxplorer is able to take ngd as input, I only used the xst generated ncd so far.
Thank you!
