wangxilinxnewer
Stuck at "Initializing design" during implementation
During implementation the process showed "initializing design" and stuck at this state. There are no errors, and runme.log is not updated. I don't know why?
OS: Windows10, Vivado 2018.3
wangxilinxnewer
The problem was resolved.
1. Closing and reopening vivado is useless.
2. restart PC, do synth and implementation again. In this way, the problem is solved.
hongh
Hi, @wangxilinxnewer ,
1. Can you try to recreate the project and rerun implementation?
2. Can the below steps work?
   <1> Open the synthesized design
   <2> write_checkpoint synth.dcp
   <3> open_checkpoint synth.dcp
   <4> run opt_design
wangxilinxnewer
fshenmi
Well, I can see that this problem persists on 2019.1 as well.
There's a short workaround without resorting to restart.
The problem appears to be the runme.log is locked and never gets refreshed.
Just forcely delete the entire impl_1/ folder with some sort of unlocking tool.
