Stuck in Phase 3 Initial Routing in VIvado 16.4
I am trying to implement my design but it got stuck at phase 3 initial routing. I tried running the same design in a new project but got stuck again. Have anyone encountered this before. Please help!!
Re: Stuck in Phase 3 Initial Routing in VIvado 16.4
Hi @lochanamendis. Is the implementation log file available? Also, Can you check the timing (WNS,TNS,WHS,THS) after placement by opening the post-place DCP, and reporting timing?
It was due to unconnected ports in dsp ip block that i used. I replaced it with a low level dsp block and it worked fine. Thanks
