Sub-optimal placement for a BUFG-BUFG cascade pair -> how to solve?
Hi All,
I've got the [Place 30-120] Sub-optimal placement for a BUFG-BUFG cascade pair error.
I understand that the error occurs because BUFG cannot be cascaded...
Please see below the "problematic" logic. As you could see, clock mux's output is connected to the clock gated cell. I guess this is the problem. So, how to solve? The clock mux's output drives several inst0 and inst1 without any clock gating, but the same clock should be gated for inst2 (see the picture below).
How to implement this logic without placement errors?
Thank you!
Re: Sub-optimal placement for a BUFG-BUFG cascade pair -> how to solve?
HI @dmitry1417
Open synthesized design, In the netlist tab, select the BUGMUX  primitve and drag it on the device view , place it some BUFG location at the center of the device.
Do the same  for the BUFGCE instance and place it on BUFG location adjacent to the BUFGMUX location.
when you save , respective LOC constraints will  be written into the xdc file.
Bharath
Please mark the Answer as "Accept as solution" if information provided addresses your query/concern.
Hi @dmitry1417
I assume that you are using 7 series device.
If only 2 BUFG's are cascaded, the tool should be able to find optimal locations for them. What are the drivers of BUFMUX?
Deepika.
yes, this is zynq 7020
clk0 and clk1 are input pins, clk_g also goes to output pin of the device
@dmitry1417,
There are specific rules which needs to be followed when using cascaded BUFG. Please check page number 35 in below 7 series clocking resource user guide:
http://www.xilinx.com/support/documentation/user_guides/ug472_7Series_Clocking.pdf
Make sure you are not violating any rule.
Can you check what other loads are driven by clk?
--Syed
HI @dmitry1417
How many BUFG are there in your design.
Can you try LOC the BUFGMUX and BUFGCE to adjacent locations..
LOC those BUFGs to the same half of the device  in which the IO bank of the clk0 and clk1 input ports is present
Bharath
How can I LOC the BUFGs? Thank you
Hi @dmitry1417
You can use below constraint
set_property LOC BUFGCTRL_XxYy [get_cells bufg_instance_name]
Deepika.
As for BUFGCTRL_XxYy, is the XxYy location coordinates? How to know the XxYy?
How can I do the same via GUI?
Thank you
HI @dmitry1417
Bharath
@dmitry1417,
In Vivado GUI, You can use the drag and drop option which will easily place/loc the instance at desired location.
Please check page number 67 in below user guide which gives details on drag and drop of instances:
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2012_2/ug893-vivado-ide.pdf
Once you save the design then the changes will be captured in constraint file.
--Syed
Thanks!
@dmitry1417,
If the issue is resolved  then please close this thread by marking the post which helped as "Accept as Solution"
--Syed
Solved :-)
你好,我使用的是virtex ultraScale+,我也遇到了这样的问题,请问:
没搞懂这是什么意思,能解释清楚一点么?谢谢
