fpgalearner
Voyager
Voyager
Submodule not get instantiated
I have a design in vu440. A top Module and several submodules. One submodule have problem. It is inside generate statement with 32 of the same submodule.
When I take only one of the this submodule, its gets instantiated inside top module and also works as expected but when I instantiate all 32 of submodule within generate statement, it doesn’t get instantiated and oviously design doesn’t work.
But it works in vcs simulation.
Vivado doesn’t report any error during implementation and timing is also clean.
What could be the reason?
rshekhaw
Hi @fpgalearner ,
I guess the particular sub modules are getting trimmed out.
If that is the scenario,  please run synthesis with -verbose and in log we can have info or warning on why the particular modules are getting trimmed out.
Raj
fpgalearner
Voyager
Voyager
@rshekhaw
with -verbose option I got several of these:
INFO: [Opt 31-315] Cell of type LUT6 is reduced to LUT4, due to redundant pins:
INFO: [Opt 31-47] Cell absorbed into downstream logic: LUT1 cell genblk4[4].I_0_
INFO: [Opt 31-131] Removed net:
and don't know why?
marcb
Hi @fpgalearner
The "redundant pins" would imply that the source is the same. This should be viewable from the elaborated design. Is this the case? Adding a KEEP or DONT_TOUCH might resolve the issue.
fpgalearner
Voyager
Voyager
@marcb @rshekhaw
By using only opt_design -retarget option instead of default opt_design the trimming doesn't happen but the design doesn't work. I think this is because of big timing violation. which I am fixing now in place and route design by adding directives instead of default as:
 place_design  -directive AltSpreadLogic_high
route_design  -directive AlternateCLBRouting
But it took 23 hours to build. Yes you read right 23 hours. I don't know if it is normal for big design?
and the resource consumption of the design in vu440 is very high:
1. CLB Logic
|          Site Type         |   Used  | Fixed | Available | Util% |
| CLB LUTs                   | 2185697 |     0 |   2532960 | 86.29 |
|   LUT as Logic             | 2185316 |     0 |   2532960 | 86.28 |
|   LUT as Memory            |     381 |     0 |    459360 |  0.08 |
|     LUT as Distributed RAM |     336 |     0 |           |       |
|     LUT as Shift Register  |      45 |     0 |           |       |
| CLB Registers              | 1486679 |     0 |   5065920 | 29.35 |
|   Register as Flip Flop    | 1481303 |     0 |   5065920 | 29.24 |
|   Register as Latch        |    5376 |     0 |   5065920 |  0.11 |
| CARRY8                     |    6248 |     0 |    316620 |  1.97 |
| F7 Muxes                   |     125 |     0 |   1266480 | <0.01 |
| F8 Muxes                   |       3 |     0 |    633240 | <0.01 |
| F9 Muxes                   |       0 |     0 |    316620 |  0.00 |
If opt_design is completely removed and take only synth, place and route, does it have any impact on overall design? better to say generated bitfile?
rshekhaw
Hi @fpgalearner ,
Opt_design is mandatory phase, it should not be skipped:
• opt_design
• power_opt_design (optional)
• place_design
• phys_opt_design (optional)
• route_design
• write_bitstream
Regarding large runtime please check below AR#:
https://www.xilinx.com/support/answers/71571.html
Raj
fpgalearner
Voyager
Voyager
@rshekhaw
The opt_design command performs the following optimizations by default:
   *  Retarget
   *  Constant Propagation
   *  Sweep
   *  Global Buffer (BUFG) optimizations
   *  DSP Register optimizations
   *  Shift-Register Logic optimizations
   *  Block RAM Power optimizations
   *  Implement MIG cores
   *  Implement Debug cores
but taking only one option like opt_design -retarget is OK?
rshekhaw
Hi @fpgalearner .
In that sense, yes you can until and unless your design is functioning correctly.
Raj
fpgalearner
Voyager
Voyager
@rshekhaw @marcb
I synthesized separately the submodule having more logics with -mode out_of_context in Vivado GUI, synthesis doesn't report any error but the resource utilization graph shows 138 % LUT. See attachment.
But when I try to open synthesized design, It takes about 1 hour to open and after that vivado crash. Therefore I can't check resource_utilization command.
Does it mean this design can not be implemented in this vu440 device and need even bigger FPGA?
or I am doing something wrong?
marcb
Hi @fpgalearner.
The utilization can be checked with the post-synthesis design. I would suggest doing so by opening the synthesized design, and entering report_utilization. This should be lower after opt_design.
Since you are only using the opt_design -retarget argument, the other default stages are not preformed. The -sweep & -propconst arguments will remove much of the unnecessary logic, which might allow the utilization to fit the architecture
fpgalearner
Voyager
Voyager
@marcb concerning "The utilization can be checked with the post-synthesis design. I would suggest doing so by opening the synthesized design, and entering report_utilization. This should be lower after opt_design."
It can not be opened. It took 1 hr then Vivado crashes.
marcb
Hi @fpgalearner
A couple things to try would be:
fpgalearner
Voyager
Voyager
@marcb @rshekhaw
using (* DONT_TOUCH = “yes” *) like this has solved trimming problem:
 generate
         for (genvar i=0; i<ds; i=i+1) begin
(* DONT_TOUCH = “yes” *) example_dt_ver U0
(.clk(clk),
.in1(a),
.in2(b),
out1(c));
         end
   endgenerate
and consumes only 18 % resources but design doesn't work as expected.
Is (* DONT_TOUCH = “yes” *) goes above generate like?
generate
 example_dt_ver U0
(.clk(clk),
.in1(a),
.in2(b),
out1(c));
         end
   endgenerate
calibra
@fpgalearner
Have you try to compile the submodule out_of_context and instantiate it as an IP.
== If this was helpful, please feel free to give Kudos, and close if it answers your question ==
fpgalearner
Voyager
Voyager
@calibra
yes, in that case I got bitwidth of a port mismatch error.
calibra
@fpgalearner
"yes, in that case I got bitwidth of a port mismatch error. "
Do you know why ?
fpgalearner
Voyager
Voyager
@calibra
well, 2 bits of a vector port is provided constant value.
calibra
@fpgalearner
Sorry but i don't understand.
You got a port mismatch bitwidth  error.
So the out_of_order compiler remove 2 output port bits ?
