Nikhil_Thapa
Synthesis and Implementation Out-of-date
Hello everyone,
I am using Vivado 2020.1 to create the block design. Every time I complete the synthesis or implementation, I always get Out-of-date . And whenever I do "Run Implementation or Generate Bitstream" next time, the process always starts from the beginning regardless of Synthesis completion. This has taken lot of time to complete the bitstream generation for a single design. I also did Force up-to-date but did not help.
Are there other ways to solve this issue?
Thanks and Regards,
Edit: My design has vmixer and vframe buffer read IP. These IPs mostly go out-of-date.
nikhil@logictronix.com
:::::Do not forget to Accept as solution, give Kudo and Share a post that you think is helpful:::::
watari
Hi @Nikhil_Thapa
Which OS are you using Vivado 2020.1 ?
If linux, is working directory on NFS ?
I'm not sure. But Vivado estimate update by difference of time stamp.
If ex. minimum time unit of time stamp is different between working directory and system, Vivado recognize that files are updated.
So, if you avoid it, you consider time stamp of all files.
bruce_karaffa
Are you running any pre-synthesis tcl scripts?  If so, these can throw everything out of date.
