TCL Command to get Current Active Implementation
All:
     I'm trying to write a TCL script to rename .bit files with a revision number.  I need a way for Vivado to tell me the name of the active implementation.  For example, if my active implementation is impl_5, I need to know this so I can find the correct .bit file.  Is there a way for a Vivado TCL script to get the currently active implementation name?
          Marv
Hi @marvinscheinbart
You can use tcl command current_run -implementation to achieve this.
Rohit
Rohit
Rohit
Rohit
Hi @marvinscheinbart,
Check if this XAPP1232 helps in your application: https://www.xilinx.com/support/documentation/application_notes/xapp1232-bitstream-id-with-usr_access.pdf
Prathik
Please mark the appropriate post as an answer "Accept as solution" in case it helps to resolve your query.
thakurr:
    This worked great.  That's all I needed.
           Marv
Prathikm:
     This was great information but it doesn't help.  I need to modify the .bit file name so it can be checked into our revision control system.  The file name allow for easy identification of the correct file.
         Marv
