Visitor dafeldib
The implementation process keeps ignoring my ucf file when running my tcl script!!
I do implement my design using GUI with no problems. Sometimes, the tools just ignores the ucf file. I just remove it from the project then add it again and rerun the implementation and voila it is seen and taken into consideration.
However, now I want to run the same using tcl script. I add the ucf file to my project and run implementation. No error /warning messages are given, but my .ucf file is totally ignored. It contains some LOC and some net assignment constraints.
Attached are my ucf and tcl files.
Re: The implementation process keeps ignoring my ucf file when running my tcl script!!
Trying adding option -uc in Translate process.
project set "Other Ngdbuild Command Line Options" "uc xxx.ucf" -process "Translate"
Which version of vivado do you use ?
Why you don't use read_xdc command tcl?
nonsense
Visitor dafeldib
Thanks Moderator, this solved my issue, I just had to add a dash before uc such that the command looks like this:
project set "Other Ngdbuild Command Line Options" "-uc xxx.ucf" -process "Translate"
Please, mark the post as solved.
Thanks again!!!
