Timing passes and all nets route, but I get a warning about not meeting hold time on unroutable nets anyways
The subject is, I hope, a pretty good description, but for completeness here's the log:
Phase 8 Route finalize
Router Utilization Summary
  Global Vertical Routing Utilization    = 8.62186 %
  Global Horizontal Routing Utilization  = 9.24715 %
  Routable Net Status*
  *Does not include unroutable nets such as driverless and loadless.
  Run report_route_status for detailed report.
  Number of Failed Nets               = 0
  Number of Unrouted Nets             = 0
  Number of Partially Routed Nets     = 0
  Number of Node Overlaps             = 0
Phase 8 Route finalize | Checksum: a5d6d9cb
Time (s): cpu = 00:07:42 ; elapsed = 00:02:00 . Memory (MB): peak = 3396.734 ; gain = 0.000 ; free physical = 1743 ; free virtual = 22715
Phase 9 Verifying routed nets
 Verification completed successfully
Phase 9 Verifying routed nets | Checksum: a5d6d9cb
Phase 10 Depositing Routes
Phase 10 Depositing Routes | Checksum: 15b15948e
Time (s): cpu = 00:07:46 ; elapsed = 00:02:04 . Memory (MB): peak = 3396.734 ; gain = 0.000 ; free physical = 1743 ; free virtual = 22715
Phase 11 Post Router Timing
INFO: [Route 35-20] Post Routing Timing Summary | WNS=0.069  | TNS=0.000  | WHS=0.043  | THS=0.000  |
INFO: [Route 35-61] The design met the timing requirement.
Phase 11 Post Router Timing | Checksum: 106eacd36
Time (s): cpu = 00:08:27 ; elapsed = 00:02:13 . Memory (MB): peak = 3396.734 ; gain = 0.000 ; free physical = 1741 ; free virtual = 22713
WARNING: [Route 35-426] Router was unable to fix hold violation on unroutable pins. The router cannot add routing detours to improve hold time because the pins are part of one or more of the following unroutable types: partition pins, fixed routes and intra-site connections.
Resolution: Run report_timing_summary to analyze the hold violations.
When I run report_timing_summary or report_timing, no violations are found and all nets are reported as routed.
Re: Timing passes and all nets route, but I get a warning about not meeting hold time on unroutable nets anyways
Hi @tas-genia
Thanks for sharing the DCP files.
I was able to recreate the issue in vivado 2016.1 internal build. I have filed CR 948651 and addressed this issue to factory.
Deepika.
I forgot to mention that I'm using Vivado 2015.4.
Hi @tas-genia
Did you run report_route_status on implemented design?
Do you see any nets with routing errors when you run this command?
Hi @tas-genia
This looks to like false message. Can you share the post place or post place phys opt DCP file?
Deepika.
report_route_status
Design Route Status
                                               :      # nets :
   # of logical nets.......................... :      114339 :
       # of nets not needing routing.......... :       38318 :
           # of internally routed nets........ :       29632 :
           # of nets with no loads............ :        8686 :
       # of routable nets..................... :       76021 :
           # of fully routed nets............. :       76021 :
       # of nets with routing errors.......... :           0 :
This is report_route_status against my post-route checkpoint.
Deepika,
I am using a custom batch-mode flow rather than a project. I save 3 checkpoints, here is the order of operations:
1. Synthesize design, read OOC IP cores (netlist is complete)
2. Save post_synth.dcp
3. Run tandem PROM TCL script from PCIe IP core
4. opt_design
5. place_design
6. Save post_place.dcp
7. phys_opt_design
8. route_design
9. Save post_route.dcp
Let me know whether you'd like post_place or post_route, and how to get it to you.
I can also edit in additional checkpoints, but I have to inform you that I've just re-run my build script and I didn't get the warning this time. No changes to IP cores or RTL. The utilization report shows a small difference in the number of LUTs and FFs from the run yesterday which generated the warning. I'm guessing there is run-to-run variance due to dynamically partitioning work to threads.
Hi @tas-genia
You can send me post place checkpoint. I will send you ezmove package to upload file.
Deepika.
Hi @tas-genia
Deepika.
Hi @tas-genia
If your query is addressed, please close the thread by marking the answer.
Deepika.
 ask what the resolution to this issue was? I'm currently seeing the exact same issue in 2017.1.
David
Hi @dwoods
The CR which I filed was fixed in vivado 2016.3.
You might be running in to different issue. If the timing is met on the design, this message can be ignored. Which device are you using?
Deepika.
@dwoods,
For better responses, Can you please create a new forum topic for this query?
--Syed
