embedded
Advisor
Advisor
Tri mode Ethernet MAC problem in Vivado 2014
Hi all,
I am using a tri mode EMAC for a Kintex-7 in Vivado. I have already worked with this core in ISE 14.7. I receive a "Critical Warning" when starting implementation and consequently errors during implementation. Below picture shows the critical warning:
I tried to comment this line in  the file -MyEth.xdc. But, it is not writable and I couldn't change this file. I looked further in core features and didn't realize how I can customize the core in order to prevent it from generating and inserting those lines into xdc file?!
I would appreciate any comment.
Hossein
Hossein
syedz
@embedded,
Constraint in IP are scoped and it is expected that you connect these pins directly to top level ports.
In case of scoped constraints the get_ports returns top level ports if the IP Ports are connected directly to top level ports. If the ip ports are not connected to top level ports directly then get_ports is converted to get_ pins.
Please check page 40 in below User guide:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_2/ug903-vivado-using-constraints.pdf
--Syed
embedded
Advisor
Advisor
Thanks for your answer. It seems that this core - here in Vivado - is wrapped with IOBs and must be connected directly to the top level entity ports. I have only observing one issue now. Some GMII_TXD IOs fail in timing at the final stage of bit file generation?! I don't see how I can manage with this problem? I am new to Vivado and need more help to find where and how exactly I can give adequate timing constraints?
Hossein
Hossein
