JPK17
UART1 as EMIO causing error.
Hi all,
I am using zynq Arty-Z7-20 board. Vivado version v2020.2.
I have mentioned steps followed and shared my block design.
1. UART1 --> EMIO
2. UART1 TX [external] --> to pin Y18 (Arty-Z7-20)/JA PMOD, Pin 1 --> constraints file.
3. UART1 RX [external] --> to pin Y19 (Arty-Z7-20)/JA PMOD, Pin 2 --> constrainst file.
ie...
set_property -dict { PACKAGE_PIN Y18 IOSTANDARD LVCMOS33 } [get_ports { ja_r1 }];
set_property -dict { PACKAGE_PIN Y19 IOSTANDARD LVCMOS33 } [get_ports { ja_t1 }];
block design
4. When I build project without setting UART1 as EMIO it works.
5. Synthesized/Implemented and Generated Bitstream with no issues
6. After setting UART1 as EMIO on build project several time, I have got this critical warnings.
WARNING: [Vivado 12-584] No ports matched 'led[0]'. [/home/jaypatel/fpga/vivado/pps_project/pps_project.srcs/constrs_1/new/pps_const.xdc:23]
WARNING: [Vivado 12-584] No ports matched 'led[1]'. [/home/jaypatel/fpga/vivado/pps_project/pps_project.srcs/constrs_1/new/pps_const.xdc:24]
WARNING: [Vivado 12-584] No ports matched 'led[2]'. [/home/jaypatel/fpga/vivado/pps_project/pps_project.srcs/constrs_1/new/pps_const.xdc:25]
WARNING: [Vivado 12-584] No ports matched 'led[3]'. [/home/jaypatel/fpga/vivado/pps_project/pps_project.srcs/constrs_1/new/pps_const.xdc:26]
WARNING: [Vivado 12-584] No ports matched 'btn[0]'. [/home/jaypatel/fpga/vivado/pps_project/pps_project.srcs/constrs_1/new/pps_const.xdc:29]
WARNING: [Vivado 12-584] No ports matched 'btn[1]'. [/home/jaypatel/fpga/vivado/pps_project/pps_project.srcs/constrs_1/new/pps_const.xdc:30]
WARNING: [Vivado 12-584] No ports matched 'btn[2]'. [/home/jaypatel/fpga/vivado/pps_project/pps_project.srcs/constrs_1/new/pps_const.xdc:31]
WARNING: [Vivado 12-584] No ports matched 'btn[3]'. [/home/jaypatel/fpga/vivado/pps_project/pps_project.srcs/constrs_1/new/pps_const.xdc:32]
I don't understand completely because, it works properly when I set UART1 as MIO[48-49].
What is the issue in viavdo?
syedz
@JPK17
From the warning, it looks like the tool is not able to find the ports in design that are mentioned at pps_const.xdc (line 23). Can you open the synthesized design and run the following TCL command to check if the ports exist?
get_ports led[0]
get_ports btn[0]
--Syed
syedz
@JPK17
get_ports led[0]
get_ports btn[0]
--Syed
JPK17
@syedz
thanks,
set_property -dict { PACKAGE_PIN xxx IOSTANDARD LVCMOS33 } [get_ports { led[0] }];
set_property -dict { PACKAGE_PIN xxx IOSTANDARD LVCMOS33 } [get_ports { btn[3] }];
I have already defined all the buttons and leds.
It works properly until I set UART1 as EMIO.
After that it starts giving that critical warnings.
Regard,
JPK17
