Ultra Scale MIG place error
Hi all,
I have a MIG(DDR4) example design in Vivado 2017.1 targeting for kintex ultrascale. After Assigning pin constraints, I tried to implement the design. But following errors occurred.  How to rectify them?
ERROR: [Place 30-689] Failed to place BITSLICE_CONTROL cell u_ddr4_0/inst/u_ddr4_mem_intfc/u_mig_ddr4_phy/inst/generate_block1.u_ddr_xiphy/byte_num[2].xiphy_byte_wrapper.u_xiphy_byte_wrapper/I_CONTROL[1].GEN_I_CONTROL.u_xiphy_control/xiphy_control on site BITSLICE_CONTROL_X0Y15 because Instance u_ddr4_0/inst/u_ddr4_mem_intfc/u_mig_ddr4_phy/inst/generate_block1.u_ddr_xiphy/byte_num[2].xiphy_byte_wrapper.u_xiphy_byte_wrapper/I_CONTROL[1].GEN_I_CONTROL.u_xiphy_control/xiphy_control can not be placed in CONTROL of site BITSLICE_CONTROL_X0Y15 because the bel is occupied by u_ddr4_0/inst/u_ddr4_mem_intfc/u_mig_ddr4_phy/inst/generate_block1.u_ddr_xiphy/byte_num[2].xiphy_byte_wrapper.u_xiphy_byte_wrapper/I_CONTROL[0].GEN_I_CONTROL.u_xiphy_control/xiphy_control(port:). This could be caused by bel constraint conflict. Please check if the cell is used correctly in the design.
ERROR: [Place 30-691] Failed to place TX_BITSLICE_TRI cell u_ddr4_0/inst/u_ddr4_mem_intfc/u_mig_ddr4_phy/inst/generate_block1.u_ddr_xiphy/byte_num[2].xiphy_byte_wrapper.u_xiphy_byte_wrapper/I_TRISTATE[1].GEN_TRISTATE.u_xiphy_tristate/xiphy_bitslice_write on site BITSLICE_TX_X0Y15 because Instance u_ddr4_0/inst/u_ddr4_mem_intfc/u_mig_ddr4_phy/inst/generate_block1.u_ddr_xiphy/byte_num[2].xiphy_byte_wrapper.u_xiphy_byte_wrapper/I_TRISTATE[1].GEN_TRISTATE.u_xiphy_tristate/xiphy_bitslice_write can not be placed in TRISTATE_TX_BITSLICE of site BITSLICE_TX_X0Y15 because the bel is occupied by u_ddr4_0/inst/u_ddr4_mem_intfc/u_mig_ddr4_phy/inst/generate_block1.u_ddr_xiphy/byte_num[2].xiphy_byte_wrapper.u_xiphy_byte_wrapper/I_TRISTATE[0].GEN_TRISTATE.u_xiphy_tristate/xiphy_bitslice_write(port:). This could be caused by bel constraint conflict. Please check if the cell is used correctly in the design.
Re: Ultra Scale MIG place error
Hi @anoopjoseph
Are you using project mode or non-project mode? Is this a flat design or are you using PR flow?
Can you share DDR4 IP XCI file and the XDC file generated using below command?
write_xdc -cell <mig_instance_name> <constr>.xdc
Deepika.
Hi Deepika,
Thanks for the reply.
Actually I am in the process of using MIG in non-project flow.
For that I created a project and MIG IP in GUI. Then I created a new project in GUI with only .sv files generated from previous project.
Could you please tell me what else I have missed? or is it not the correct way?
Anoop
Hi @anoopjoseph
So you are trying to use IP RTL instead of IP XCI?
This is not a recommended flow. Is there any specific reason behind using IP RTL instead of its XCI? Can you try using IP XCI instead?
MIG PHY is implemented during opt_design in normal flow. It looks like this is not happening when you use RTL instead of XCI.
Deepika.
Hi  ,
When I used .XCI for DDR4 MIG, it worked. Thanks for your advice.
In non-project flow, can I use the .XCI alone for MIG?
Anoop
Hi @anoopjoseph
Yes, reading in the XCI using read_ip command should be sufficient. You have use generate_target and synth_ip command if the IP is not generated.
Deepika.
@vemulad,
In my existing project( non project mode flow), I have added ddr4_0.xci. After that there is an error after synthesis(Added at last part ), Could you please check what is it? .
In the script file for project flow, below steps are already there
generate_target all [get_files *.xci]
synth_ip [get_files *.xci]
get_files -all -of_objects [get_files *.xci]
Part of Vivado log
1577 Infos, 412 Warnings, 0 Critical Warnings and 0 Errors encountered.
synth_design completed successfully
synth_design: Time (s): cpu = 00:04:12 ; elapsed = 00:06:01 . Memory (MB): peak = 3085.652 ; gain = 1105.926 ; free physical = 151872 ; free virtual = 310089
INFO: [Coretcl 2-1174] Renamed 1142 cell refs.
INFO: [Timing 38-35] Done setting XDC timing constraints.
INFO: [Timing 38-2] Deriving generated clocks
INFO: [Common 17-1381] The checkpoint '/home/project/ddr4_0/ddr4_0.dcp' has been generated.
write_checkpoint: Time (s): cpu = 00:00:16 ; elapsed = 00:00:12 . Memory (MB): peak = 3107.699 ; gain = 22.047 ; free physical = 151813 ; free virtual = 310038
ERROR: [Vivado 12-3437] This command only supports sub-design files marked for netlist generation. To enable this functionality, set the GENERATE_SYNTH_CHECKPOINT property to true. If the GENERATE_SYNTH_CHECKPOINT property is marked read-only, then select 'Report IP Status' from the 'Tools' menu, or run the 'report_ip_status' Tcl command to see why the sub-design is locked.
INFO: [Common 17-206] Exiting Vivado at Thu Jan 18 15:11:37 2018...
Hi @anoopjoseph
Try using below command
set_property GENERATE_SYNTH_CHECKPOINT TRUE [get_files .xci]
Deepika.
Could you please tell me at which position I need to give this command ? (like before/after generate_target etc).
Because , I had tried this option. But had failed with another error.
Anoop
@vemulad,
This is the error I got.
par of vivado log
USER: Adding IP /home/project/ddr4_0/ddr4_0.xci
# set_property GENERATE_SYNTH_CHECKPOINT TRUE [get_files ddr4_0.xci]
# generate_target all [get_files *.xci]
ERROR: [Vivado 12-3563] The Nested sub-design '/home/project/ddr4_0/ip_0/ddr4_0_microblaze_mcs.xci' can only be generated by its parent sub-design.
Hi @anoopjoseph
Can you show me the error? Below is the order.
Deepika.
@vemulad,
par of vivado log
Hi @anoopjoseph
This flow is working at my end. Can you try specifying the DDR4 IP name in the below command?
 generate_target all [get_files ddr4_0.xci]
Attached is the log file of my run for your reference.
Deepika.
@vemulad
Thanks I will try.
Then what about other XCIs in design? do they need generate_target?
Anoop
Hi @anoopjoseph
Yes, if they are not generated.
If this works then you may have to use separate commands for MIG and other IP's.
Deepika.
set_property GENERATE_SYNTH_CHECKPOINT TRUE [get_files *.xci]
Below are the subsequent commands
set_property top ${design_name} [current_fileset]
read_xdc
set default_lib xil_defaultlib
get_property PACKAGE [get_parts ${device}]
synth_design -top ${design_name} -part ${device}
write_checkpoint -force ${design_name}_post_synth.dcp
write_verilog -force ${design_name}.vnet
Hi @anoopjoseph
Please share your script and log files.
Deepika.
Hi @vemulad,
I am sorry. I cannot share my original files. (It is controlled).
This flow was working fine until I add ddr4_0.xci in the file list for synthesis and implementation.
Actually I am not so familiar with non project type flow. Any other problem can you see?
If I need to share the files, I need to create a sample environment  and reproduce the problem. Which may take some time.
Anoop
Hi @vemulad
When I separated synth_IP commands separately , I could implement my design.
Instead of
I gave
synth_ip [get_files A.xci]
synth_ip [get_files B.xci] etc
synth_ip [get_files ddr4_0.xci]
Could you please explain why this happened?
What I understood is that I need to separate synth_IP command for DDR4 from other XCI. Is it correct?
Is there any single commands to do so?
Like,
synth_ip [get_files *.xci] //except DDR4
Anoop
