joe306
Understanding PBlocks
Hello, newbie here, can anyone point me in the direction for documentation on when to use Pblocks and their purpose?
Thank you
Joe
maps-mpls
Mentor
Mentor
Have you taken a look at UG909?  PBLOCKs are used in PR/DFX, so there is some information.
Also, if you have DocNav, open it up, do a search, make sure you check Search Docs, and search for PBLOCK.  Lots of good stuff there.
*** Destination: Rapid design and development cycles *** Unappreciated answers get deleted, unappreciative OPs get put on ignored list ***
abouassi
Hi @joe306,
Check this thread.
Abdallah
maps-mpls
Mentor
Mentor
joe306
Thank you very much
maps-mpls
Mentor
Mentor
You're welcome. I'm always happy to help somebody looking for a pointer on where to dig in.  I hope it helps out.
syedz
@joe306
Also, check this quick take video which covers pblock topic basically used for floorplanning and has an example:
https://www.xilinx.com/video/hardware/design-analysis-floorplanning-with-vivado.html
--Syed
joe306
Thank you very much for sharing this information.
Joe
