dick0329
Updating cell properties after run implemenation
I have finished my design in 7-Series GTP RX with properties RX_CM_SEL= 2'b00 then generated bit file.
Now I need generate another bit file base on same design but change some GTP properties (for example : RX_CM_SEL = 2'b10).
My approach as below step...
(1) open implementation design
(2) find cell gtpe2_i
(3) change gtpe2_i properties (for example : RX_CM_SEL = 2'b10)
(4) generate bit file again (without re-synthesis and re-implementation)
Is this approach correct and no side effect?
vemulad
Hi @dick0329
As you are only changing cell properties, I don't foresee any issue.
Make sure you generate the bitfile using write_bitstream command from TCL console.
Deepika.
