Visitor dawang
Using 18.1 netlists as reference in 18.3 Vivado, Vivado 18.3 gives up on the incremental flow, even though the logic diff is very small.
Hi, Vivado experts
I have some minor design changes I would like to use the incremental flow to fast timing closure.
My reference netlist1 was generated in 18.1. The timing was met in netlist1. I have a new netlist2, which was also generated in 18.1, timing was not met. I could use the 18.3 to read dcp file of the new netlist2 and run through incremental flow with reference set to netlist1, to make netlist2 timing meet. This indeed shows the adavntages of using increamental flow.
1. Reuse Summary
| Type | Matched % (of Total) | Reuse % (of Total) | Fixed % (of Total) | Total |
| Cells | 99.76 | 99.77 | 0.13 | 586755 |
| Nets | 99.73 | 99.66 | 0.00 | 569873 |
| Pins | - | 99.69 | - | 2450580 |
| Ports | 100.00 | 100.00 | 100.00 | 670 |
* Reused % can exceed matched % when unmatched cells take their placement directly from other cells that have been matched
However, I synthesize the same RTL with 18.3 from scratch, and generated netlist3. When I used netlist3 against netlist1 in the incremental flow of 18.3, Vivado says two netlists do not meet incremental threashold, so the tool gives up.
I am very sure the design difference is very small. Not sure how this could happen. One thing I could guess is the transceivers IPs are updated from 18.1 to 18.3.
Time (s): cpu = 00:00:54 ; elapsed = 00:01:51 . Memory (MB): peak = 10581.301 ; gain = 0.000 ; free physical = 25338 ; free virtual = 54469
WARNING: [Project 1-964] Cell Matching & Net Matching is less than the threshold needed to run Incremental flow. Switching to default Implementation flow
Any suggestions is very appreciated!
David
Re: Using 18.1 netlists as reference in 18.3 Vivado, Vivado 18.3 gives up on the incremental flow, even though the logic diff is very small.
@dawang
After reading netlist 3 for top design and reading netlist 1 for incremental compilation, run the following command and check the reuse percentage:
report_incremental_reuse
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug904-vivado-implementation.pdf#page=102
example:
open_checkpoint netlist3.dcp
read_checkpoint -incremental netlist1.dcp
--Syed
Visitor dawang
Looks like no further info when Vivado decided backoff. Below are feedbacks from Vivado.
INFO: [Vivado_Tcl 4-1062] Incremental flow is disabled. No incremental reuse Info to report.
Any other suggestions?
@dawang
Can you share the files to debug the issue?
--Syed
