Newbie ambar686
VHDL program NgdBuild:604 error
hi !! i was designing a full adder using two half adder using the following program in VHDL programming in Xilinx ISE 9.2i, but constantly i got the same error. please help me. any suggestion is acceptable.
the name of vhd file is fulladd.vhd.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
---- Uncomment the following library declaration if instantiating
---- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity fulladd is
Port ( a1 : in STD_LOGIC;
b1 : in STD_LOGIC;
cin : in STD_LOGIC;
sum : out STD_LOGIC;
car : out STD_LOGIC);
end fulladd;
architecture fullad of fulladd is
component ha
port(a: in std_logic;
b: in std_logic;
sha,cha: out std_logic);
end component;
signal s1,c1,c2:std_logic;
begin
H1: ha port map(a1,b1,s1,c1);
H2: ha port map(s1,cin,sum,c2);
car<=c1 or c2;
end fullad;
the ERROR i m getting is:
ERROR:NgdBuild:604 - logical block 'H1' with type 'ha' could not be resolved. A
pin name misspelling can cause this, a missing edif or ngc file, or the
misspelling of a type name. Symbol 'ha' is not supported in target
'xa9500xl'.
ERROR:NgdBuild:604 - logical block 'H2' with type 'ha' could not be resolved. A
'xa9500xl'.
please help me as fast as you can, its my final year project.
Re: VHDL program NgdBuild:604 error
Did you add the ha module to the project?
The tool is unable to find this ha module and hence it says that it is taking it as black box.
At translate level, it actually checks for the ngc/edif og the submodule, if it doesnot find it will error out.
So add the submodule definition to the project.
Deepika.
Deepika.
Please refer this article: http://www.xilinx.com/support/answers/9838.htm
Yash
