Visitor pallab.m
VIrtex 5 and Vivado HSL
I have a Digilent XUP Virtex 5 FPGA board. I have installed the Xilinx design Suite with Vivado HSL. When I started creating projects on Vivado, I was only able to find Kintex 7, Artix 7 and Virtex 7 families in part selection of synthesis settings.
Can't I use Vivado to program my Virtex 5 FPGA board?
Re: VIrtex 5 and Vivado HSL
Vivado only supports the 7-Series devices. Older architectures are not supported with Vivado and one must continue to use ISE for these devices like Virtex-5, Virtex-6, Spartan-6 etc.
Visitor pallab.m
Thank you.
Participant shantesh
Will older architectures such as virtex5 be supported in the next release of Vivado?
No, they will never be supported by Vivado. 7-Series and newer architectures will be supported by Vivado.
Observer jacklsw86
what are you guys going to do with those who are still using older than 7 series chips if you are going to phase out ISE in 2014? then we have no way but to use planahead?
ISE will be maintained for a time to support older architectures.
