Newbie nealpalmer
VU13P 2018.3 "Inter-SLR connectivity check:" fails with 13% of SLR routing used?
I have a design that has previously gotten through 'write_bitstream' in vivado 2018.3.  I did some minor placement changes, and now it fails in 'write_bitstream' with the following errors:
ERROR: [DRC SLRC-1] Inter-SLR connectivity check: At least 29985 connections are required between SLR2 and SLR3 but only 23040 are available
ERROR: [DRC SLRC-1] Inter-SLR connectivity check: At least 59287 connections are required between SLR1 and SLR2 but only 23040 are available
ERROR: [DRC SLRC-1] Inter-SLR connectivity check: At least 85217 connections are required between SLR0 and SLR1 but only 23040 are available
report_utilization shows that a low percentage is actually used in the routing:
12. SLR Connectivity
| | Used | Fixed | Available | Util% |
| SLR3 <-> SLR2 | 1747 | | 23040 | 7.58 |
| SLR2 -> SLR3 | 1198 | | | 5.20 |
| Using TX_REG only | 0 | 0 | | |
| Using RX_REG only | 0 | 0 | | |
| Using Both TX_REG and RX_REG | 0 | 0 | | |
| SLR3 -> SLR2 | 549 | | | 2.38 |
| SLR2 <-> SLR1 | 2836 | | 23040 | 12.31 |
| SLR1 -> SLR2 | 1214 | | | 5.27 |
| SLR2 -> SLR1 | 1622 | | | 7.04 |
| SLR1 <-> SLR0 | 448 | | 23040 | 1.94 |
| SLR0 -> SLR1 | 129 | | | 0.56 |
| SLR1 -> SLR0 | 319 | | | 1.38 |
| Total SLLs Used | 5031 | | | |
13. SLR Connectivity Matrix
| | SLR3 | SLR2 | SLR1 | SLR0 |
| SLR3 | 0 | 549 | 0 | 0 |
| SLR2 | 1198 | 0 | 1622 | 0 |
| SLR1 | 212 | 1214 | 0 | 319 |
| SLR0 | 83 | 83 | 129 | 0 |
Any idea why?
Re: VU13P 2018.3 "Inter-SLR connectivity check:" fails with 13% of SLR routing used?
@nealpalmer
If you have done some minor placement changes then try using incremental compilation feature in Vivado which might give good results with reduced runtime.
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug904-vivado-implementation.pdf#page=97
--Syed
Hi Neal,
Are you running report_utilization after the successful place_design or the failing one?
Did you change the synthesis settings?
-Fred
