Viewing duplicated registers
Does the tool show duplicated registers in the floorplan? I have a high fan-out flop which I am expecting to be duplicated, but I can only see the base instance in the floorplan.
Re: Viewing duplicated registers
If the FF was duplicated by the tool , you can see the duplicated FF.
Needless to say,you should open the Design(dcp) after duplicating.
If you can't see the duplicated FF , the duplication may not happened.
Look at the Synthesis or Implementation log.
Hi @justins. If you do not see the registers being replicated, you can use the MAX_FANOUT property along with the place_design -fanout_opt to replicate drivers of a net. This is covered on age 69 of the below link.
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_4/ug904-vivado-implementation.pdf#page69
*Please mark replies with the "Accept as solution" option if they are found to be helpful
