[Vivado: 12-1411] Cannot set LOC property
I have connected a single ended input signal to an n-type E26(IO_L17N_T2_A13_D29_14) pin in Bank 14 of Kintex-7 FPGA. This input signal is routed to a deserializer macro (1:10) inside the design. The design fails in the implementation stage with this warning (attached snapshot). I tried connecting the signal to a P-type pin, which results in successful implementation, however the pin for this input signal is fixed to E26, i need to find out a way to perform successful implementation. Suggestions are awaited.
Re: [Vivado: 12-1411] Cannot set LOC property
This issue can occur due to incorrect use of IBUFDS_GTE2 for MRCCs.
When differential clocks are coming from MRCCs or SRCCs, IBUFGDS/IBUFDS should be used, not an IBUFDS_GTE2.
The problem can be resolved by replacing the IBUFDS_GTE2 with an IBUFGDS/IBUFDS.
Thanks and Regards
Balkrishan
Hi @pooja.yadav
Are you changing the package pins input to p type in xdc? If yes, try adding this command after input port is set to p type package pin:
set_property IS_LOC_FIXED true [get_ports <port_name>]
Rohit
Rohit
Hi @pooja.yadav
Are you cascading ISERDES and OSERDES by any chance?
Deepika.
Hi Rohit,
I am not changing package pins input to p type. Since the input signal is a single ended signal, I am simply connected it to E26 using LVCMOS25 standard. The input has to be connected to E26 which is an n-type.
Attached snapshot from xdc file.
No. I am not cascading ISERDES and OSERDES.
Hi Balkrishan,
I haven't used any differential clocks/inputs in my design. I am not sure where you are referring to use IBUFDS/IBUFGDS.
