Observer p.hayk
Vivado 2015.4 vs 2018.2, 2018.2 loses in all aspects
Recently we moved our project from 2015.4 version to 2018.2 and we were really shocked with the bad results that 2018.2 gives in comparison to 2015.4.
The implementation time of 2018.2 increased around 6 times
So Implementation time:
2015.4 : 00:19:56
2018.2:  01:52:06
We used the same conditions i.e. same strategy, same machine, same design, same IPs. And the tools were run in parallel on same machine with same amount of threads. No other resource was using our machine, only these 2 vivados.
Than we checked the timing, slightly better results for 2018.2.
WNS:
2015.4: -4.638
2018.2: -4.777
TNS:
2015.4: -1703.105
2018.2: -548.562
WNS:
2015.4: -0.064
2018.2L -0.052
Than resource utilization:
2018.2
LUT        22024    134600  16.362555
LUTRAM              4441      46200    9.612555
FF           33019    269200  12.265602
BRAM    277.5     365        76.0274
IO           186        400        46.5
MMCM 2             10           20.0
PLL         1             10           10.0
2015.4
LUT        23818    134600  17.695395
LUTRAM              4443      46200    9.616883
FF           31999    269200  11.886701
BRAM    278        365        76.16438
IO           220        400        55.0
BUFG     18           32           56.25
MMCM 2             10           20.0
PLL         1             10           10.0
If you see very small, almost negligible benefit.
Can someone please explain how is this possible?
Like we updated almost 3 years older tool version and got worse results with the new tool. Is it expected?
P.S. 2018.2 has issue with internal text editor, when we modify the code outside of tool, the tool sometimes text-editor does not recognize our edits.
Scholar u4223374
Re: Vivado 2015.4 vs 2018.2, 2018.2 loses in all aspects
Why are your two designs using different numbers of I/O pins? Anything else I can believe, but missing I/O pins means that something is very messed-up.
The timing results are largely irrelevant - both tools work until they meet timing (or decide that they cannot meet timing) and then stop. It's quite possible that one of them could have met tighter timing requirements if it had to, but the fact that both did meet timing doesn't really tell us anything.
Apart from that, was this just implementation? Or did you re-run synthesis too? It occurs to me that if you opened a Vivado 2015.4 project in Vivado 2018.2 and run implementation immediately, it might decide to re-run synthesis first - which could easily account for a lot of time.
Scholar drjohnsmith
re the text editor problem you mention,
is it possible different files are on different machines with different clock / times ?
Ive not seen it with the editor, but other parts of vivado this seems to be a feature,
   ensure all your machines where files are located and you run vivado on are locked to the same time master
Observer p.hayk
Regarding to IOs, really strange. Still debugging
I re-run synthesis and than implementation
Observer p.hayk
Nope, same machine, same user
As this design appears to be failing timing, it may be that the older release simply gave up earlier while the newer release tried much harder to meet timing. You seem to report WNS twice - can you explain the difference here - is one the hold slack? Either way, it would be worth re running with a design where the timing can actually be met as that gives a much more realistic view of actual runtime.
