Anonymous
Not applicable
Vivado 2016.3 crashes when starting implementation
every time I try to start the implementation Vivado crashes. I'm using version 2016.3 on Ubuntu 16.04.1. I get the following error report:
# An unexpected error has occurred (11)
Stack:
/opt/Xilinx/Vivado/2016.3/tps/lnx64/jre/lib/amd64/server/libjvm.so(+0x91ab39) [0x7fe73b9ecb39]
/opt/Xilinx/Vivado/2016.3/tps/lnx64/jre/lib/amd64/server/libjvm.so(JVM_handle_linux_signal+0xb6) [0x7fe73b9f2f26]
/opt/Xilinx/Vivado/2016.3/tps/lnx64/jre/lib/amd64/server/libjvm.so(+0x917753) [0x7fe73b9e9753]
/lib/x86_64-linux-gnu/libc.so.6(+0x354b0) [0x7fe76ffa84b0]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_runsbase.so(HAXPExpRunStep::getFlowStep() const+0) [0x7fe74960b710]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_runs.so(HAXFVDIDataMgr::scriptPreCmds_(HAXPExpRunBase*, std::string&, std::string&, std::string&)+0x1e4) [0x7fe749a14da4]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_runsbase.so(HAXPScriptWriter::writePreCmds()+0x58) [0x7fe749619868]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_runsbase.so(HAXPScriptWriter::writeScript()+0x33) [0x7fe74961cf73]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_runs.so(HAXPLaunchMgr::writeRunFromFloorplan(HAXPExpRun*, HFLFloorplan*, HSTVector<std::pair<HAXPExpRun*, std::string>, std::allocator<std::pair<HAXPExpRun*, std::string> > >&, HDGUIStatus&)+0xd4) [0x7fe74994f7a4]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_project.so(HAPRRunDaemonLauncher::openDesignAndWriteRun_(HAPRDesignSpec const&, HAXPExpRun*, HSTVector<std::pair<HAXPExpRun*, std::string>, std::allocator<std::pair<HAXPExpRun*, std::string> > >&, HDGUIStatus&)+0x39c) [0x7fe74bd64afc]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_project.so(HAPRRunDaemonLauncher::exportRunForSpec_(HAXPExpRun*, HSTVector<std::pair<HAXPExpRun*, std::string>, std::allocator<std::pair<HAXPExpRun*, std::string> > >&, HDGUIStatus&)+0x9f) [0x7fe74bd6525f]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_project.so(HAPRRunDaemonLauncher::launch(HAXPLaunchOptions*, HSTVector<std::pair<HAXPExpRun*, std::string>, std::allocator<std::pair<HAXPExpRun*, std::string> > >&, HDGUIStatus&)+0x301) [0x7fe74bd65d21]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_tcltasks.so(+0x135e1fe) [0x7fe7652871fe]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_common.so(+0x5f8f57) [0x7fe771057f57]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/libtcl8.5.so(+0x331f5) [0x7fe76bf551f5]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/libtcl8.5.so(+0x76bbe) [0x7fe76bf98bbe]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/libtcl8.5.so(+0x7e767) [0x7fe76bfa0767]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/libtcl8.5.so(TclEvalObjEx+0x77) [0x7fe76bf57327]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_common.so(+0x5f866c) [0x7fe77105766c]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/libtcl8.5.so(Tcl_ServiceEvent+0x87) [0x7fe76bfc9b37]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/libtcl8.5.so(Tcl_DoOneEvent+0x129) [0x7fe76bfc9e69]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_commontasks.so(+0x304aa5) [0x7fe767df9aa5]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_commontasks.so(+0x30c28b) [0x7fe767e0128b]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_commontasks.so(+0x304d43) [0x7fe767df9d43]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_commonmain.so(+0x6430) [0x7fe77085a430]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/libtcl8.5.so(Tcl_Main+0x1d5) [0x7fe76bfc2175]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_common.so(+0x631d29) [0x7fe771090d29]
/lib/x86_64-linux-gnu/libpthread.so.0(+0x76ba) [0x7fe76fa546ba]
/lib/x86_64-linux-gnu/libc.so.6(clone+0x6d) [0x7fe77007982d]
I hope someone is able to help me resolving this.
Thank you all in advance.
Cheers
Ben
vuppala
Hi @Anonymous
1. Did you encounter this crash with every project?
2. If the crash is specific to a project, share your project.
3. Try running implementation in tcl mode.
  1. open Vivado in tcl mode: vivado -mode tcl
  2. open project: open_project /path/to/project/project_1.xpr
  3. launch implementation: launch_runs impl_1
Vinay
vijayak
Hi @Anonymous
If this crash is not design specific, try re-installing Vivado and see if that helps.
Thanks,Vijay
balkris
check these similar posts
https://forums.xilinx.com/t5/Synthesis/Vivado-2016-3-keeps-crashing-with-memory-problems-stack-dump/td-p/734333
https://forums.xilinx.com/t5/Simulation-and-Verification/Vivado-2016-3-crashing/td-p/733216
Thanks and Regards
Balkrishan
syedz
@Anonymous,
Can you try running implementation after disabling the multithreading:
https://www.xilinx.com/support/answers/50345.html
--Syed
nschroer
I had the same issue (Vivado 2016.1), with Vivado crashing as soon as I wanted to start Implementation (even when synthesis wasn't done yet). This was only happening with one project, others worked fine.
Solution for me was to delete everything in the Work/ProjectName.runs/impl_1 folder, after this implementation worked and regenerated all the files in that folder.
