Newbie michverc
Vivado 2017.4 (and 2018.2) different Implementation results between Linux and Windows
I have a design which is increasingly difficult to route in Vivado 2017.4. Most of my runs have been done on Linux. I have also tried with a Windows machine which yielded much better results.
I switched to Vivado 2018.2 which provided better results in Linux (very low TNS) and good timing in Windows (no timing violations).
I have compared the synthesis logs between the Linux and Windows runs and found no relevant differences. But comparing the implementation logs showed that in Linux the tool found the design difficult to route (high congestion) while in Windows the tool did not report congestion issues and was able to close timing.
How can I replicate the Windows results in Linux (I need to submit builds on Linux machines)?
Michel
Scholar drjohnsmith
Re: Vivado 2017.4 (and 2018.2) different Implementation results between Linux and Windows
good question
do both machines have the same amount of ram and same processor ?
   are both vivados set up the same ?
Hi @michverc. I would try comparing the logs to see where they diverge, and what is different.
It also would be helpful to use the report_timing_summary command at each stage to see where the timing changes as well.
Newbie michverc
I use the same xpr file and source files on both setups.
I have compared both synth_1 and impl_1 logs. The synth_1 runme.log are almost identical.
In the impl_1 run the congestion reports are different with the Linux version reporting high congestion while the Windows one does not. Prior to this step both logs are very similar.
Both Linux and Windows setups are Intel Xeon @2.4GHz with 16 cores and 128 GB RAM
My design is using XCVU9P. Utilization is rather low (30%) but with high congestion regions
Hi @michverc. Are the logs available? There might be more differences included that could help suggest a course of action.
Also, where does the timing diverge?
Newbie michverc
With the same input files (RTL, IPs, constraints) and same version of Vivado (2017.4 or 2018.2) should we expect different behavior between Linux and Windows?
I am running in Project mode where intermediate steps are more limited.
Hi @michverc. While every effort is made to maintain repeatability even different operating systems, a different operating system could cause the difference. More information is provided in the below answer record.
https://www.xilinx.com/support/answers/61599.html
