Visitor ugface
Vivado 2018.1 Abnormal program termination (EXCEPTION_ACCESS_VIOLATION) during routing
I just tried to implement an old project with the new Vivado 2018.1 and got "Abnormal program termination (EXCEPTION_ACCESS_VIOLATION)" during routing every time. The error happened after routing was completed, when executing "report_methodology". With Vivado 2017.3, everything was fine.
I tried to analyze Vivado's crash dump file with WinDbg and found the following info. It seemed like a bug in  librdi_psta.dll at librdi_psta!sta::VertexInEdgeIterator::VertexInEdgeIterator+d.
DUMP_CLASS: 2
DUMP_QUALIFIER: 400
CONTEXT: (.ecxr)
rax=000007fed90e9c18 rbx=0000000000000000 rcx=0000000003d27e60
rdx=0000000000000000 rsi=00000000af03ebd0 rdi=00000000c6251c90
rip=000007fed8dd0b9d rsp=0000000003d27db8 rbp=0000000003d27ec0
r8=0000000059dabc90 r9=00000000c6e1b360 r10=0000000003d27e60
r11=0001dfb904e00762 r12=0000000059dabc90 r13=000000003c182e10
r14=0000000000000038 r15=0000000000000038
iopl=0 nv up ei pl nz na pe nc
cs=0033 ss=002b ds=002b es=002b fs=0053 gs=002b efl=00010202
librdi_psta!sta::VertexInEdgeIterator::VertexInEdgeIterator+0xd:
000007fe`d8dd0b9d 8b4210 mov eax,dword ptr [rdx+10h] ds:00000000`00000010=????????
Resetting default scope
FAULTING_IP:
EXCEPTION_RECORD: (.exr -1)
ExceptionAddress: 000007fed8dd0b9d (librdi_psta!sta::VertexInEdgeIterator::VertexInEdgeIterator+0x000000000000000d)
ExceptionCode: c0000005 (Access violation)
ExceptionFlags: 00000000
NumberParameters: 2
Parameter[0]: 0000000000000000
Parameter[1]: 0000000000000010
Attempt to read from address 0000000000000010
DEFAULT_BUCKET_ID: NULL_CLASS_PTR_READ
PROCESS_NAME: vivado.exe
ERROR_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s.
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s.
EXCEPTION_CODE_STR: c0000005
EXCEPTION_PARAMETER1: 0000000000000000
EXCEPTION_PARAMETER2: 0000000000000010
FOLLOWUP_IP:
READ_ADDRESS: 0000000000000010
BUGCHECK_STR: NULL_CLASS_PTR_READ
WATSON_BKT_PROCSTAMP: 5a87f001
WATSON_BKT_MODULE: librdi_psta.dll
WATSON_BKT_MODSTAMP: 5aa2edb0
WATSON_BKT_MODOFFSET: f0b9d
BUILD_VERSION_STRING: 6.1.7601.23915 (win7sp1_ldr.170913-0600)
MODLIST_WITH_TSCHKSUM_HASH: 1110367a7a21f844a46ac594b7750da6823b0c3f
MODLIST_SHA1_HASH: b4fb8637a5b347e9e0265b357a23083e314ee265
DUMP_FLAGS: 0
DUMP_TYPE: 2
ANALYSIS_SESSION_HOST: TECHSERVER
ANALYSIS_SESSION_TIME: 04-18-2018 17:45:16.0167
ANALYSIS_VERSION: 10.0.14321.1024 amd64fre
THREAD_ATTRIBUTES:
PROBLEM_CLASSES:
NULL_CLASS_PTR_READ
Tid [0x230c]
Frame [0x00]: librdi_psta!sta::VertexInEdgeIterator::VertexInEdgeIterator
LAST_CONTROL_TRANSFER: from 000007feb52cb0d2 to 000007fed8dd0b9d
STACK_TEXT:
00000000`03d27db8 000007fe`b52cb0d2 : 00000000`00000000 00000000`af03ebd0 00000000`c6e21b10 00000000`c6e1b360 : librdi_psta!sta::VertexInEdgeIterator::VertexInEdgeIterator+0xd
00000000`03d27dc0 000007fe`b52c89fd : 00000000`b52b6900 00000000`00000000 00000000`67fc6af8 00000000`67fc6ae0 : librdi_timing!HASTDRCMgr::~HASTDRCMgr+0xc972
00000000`03d28010 000007fe`b568baae : 00000000`01000002 00000000`36be5020 00000000`36be5020 00000000`03d284e0 : librdi_timing!HASTDRCMgr::~HASTDRCMgr+0xa29d
00000000`03d28200 000007fe`d7b80023 : 00000000`0000002b 00000000`03d28839 00000000`0b21bf40 00000000`00000000 : librdi_timing!HASTUtil::ensureTimingForDRC+0x8e
00000000`03d28260 000007fe`d7b760ad : 00000000`67fc6e88 00000000`03d28978 00000000`03d289d0 00000000`03d289d0 : librdi_drc!HARCMgr::registerUserChecker+0x1293
00000000`03d28790 000007fe`a4b3db6c : 00000000`00000000 00000000`03d28990 00000000`00000000 00000000`00000000 : librdi_drc!HARCMgr::createResults+0x55d
00000000`03d28890 000007fe`a4b37e81 : 00000000`b6561170 00000000`025bf6b0 00000000`b6561170 00000000`b6561170 : librdi_coretasks!Java_ui_frmwork_bplacecmds_HTCBPlaceCommands_1placePblocks+0x24a1c
00000000`03d2bbc0 000007fe`a4b3659c : 00000000`00000000 00000000`025bf6b0 00000000`025bf6b0 00004c8b`36805d37 : librdi_coretasks!Java_ui_frmwork_bplacecmds_HTCBPlaceCommands_1placePblocks+0x1ed31
00000000`03d2bca0 000007fe`de5ce331 : 00000000`03d2c048 00000000`025bf6b0 00000000`b8547800 00000000`0024c280 : librdi_coretasks!Java_ui_frmwork_bplacecmds_HTCBPlaceCommands_1placePblocks+0x1d44c
00000000`03d2bcd0 000007fe`de5d10f6 : 00000000`025bf6b0 00000000`03d2c048 ffffffff`ffffffff 000007fe`f3e542cb : librdi_common!hdi::tcltasks::task_manager::eval_in_tcl_throw+0x261
00000000`03d2c020 00000000`6a5d11fc : 00000000`00000001 000007fe`a4c9273f 00000000`00000002 00000000`03d2c368 : librdi_common!hdi::tcltasks::task_manager::retrieve_except_msg_instance+0x4c6
00000000`03d2c210 00000000`6a616238 : 00000000`00000000 00000000`00000007 00000000`025e4018 ffffffff`ffffffff : tcl85t!Tcl_ListMathFuncs+0x58c
00000000`03d2c2c0 00000000`6a614fec : 00000000`025bf6b0 00000000`0bbd9190 00000000`00000000 00000000`00000000 : tcl85t!Tcl_ExprObj+0x1868
00000000`03d2c8c0 00000000`6a5d2e8d : 00000000`0a31c8c0 00000000`025bf6b0 00000000`0bcd11b0 00000000`03d2c980 : tcl85t!Tcl_ExprObj+0x61c
00000000`03d2c910 00000000`6a5d2acd : 00000000`03d2c988 00000000`00000003 00000000`025bf6b0 00000000`a237b140 : tcl85t!TclEvalObjEx+0x3ad
00000000`03d2c980 000007fe`e495fddb : 00000000`02620800 00000000`00312e80 00000000`0a31c8c0 00000000`0bcd11b0 : tcl85t!Tcl_EvalObjEx+0x1d
00000000`03d2c9c0 00000000`6a5d11fc : 00000000`025bf6b0 00000000`025bf6b0 00000000`88f8dc90 00000000`6a69ac3c : librdi_commontasks+0x1fddb
00000000`03d2ca40 00000000`6a5d218e : 00000000`00000000 00000000`00000003 00000000`025e3e60 00000000`88f8dc90 : tcl85t!Tcl_ListMathFuncs+0x58c
00000000`03d2caf0 00000000`6a5d2d1e : 00000000`025bf6b0 00000000`88f8dc90 00000000`00000003 00000000`00000003 : tcl85t!Tcl_EvalEx+0x99e
00000000`03d2cc20 00000000`6a5dadff : 00000000`00000000 00000000`025e3b98 00000000`025d2ce0 00000000`00000004 : tcl85t!TclEvalObjEx+0x23e
00000000`03d2cc90 00000000`6a5d11fc : 00000000`025bf6b0 00000000`00000004 00000000`025bf6b0 00000000`00000000 : tcl85t!TclDumpMemoryInfo+0x342f
00000000`03d2ccd0 00000000`6a616238 : 00000000`00000000 00000000`00000004 00000000`025e3b98 ffffffff`ffffffff : tcl85t!Tcl_ListMathFuncs+0x58c
00000000`03d2cd80 00000000`6a6612f4 : 00000000`025bf6b0 00000000`0bca4b70 00000000`025e3a48 00000000`00000000 : tcl85t!Tcl_ExprObj+0x1868
00000000`03d2d380 00000000`6a5d11fc : 00000000`00000000 00000000`025bf6b0 00000000`025e3a48 00000000`0b9e4c68 : tcl85t!TclObjInterpProcCore+0x74
00000000`03d2d3d0 00000000`6a616238 : 00000000`00000000 00000000`00000003 00000000`025e3a48 ffffffff`ffffffff : tcl85t!Tcl_ListMathFuncs+0x58c
00000000`03d2d480 00000000`6a614fec : 00000000`025bf6b0 00000000`0b7cfd50 00000000`00000000 00000000`00000000 : tcl85t!Tcl_ExprObj+0x1868
00000000`03d2da80 00000000`6a5d2e8d : 00000000`00312e80 00000000`025bf6b0 ffffffff`fffffffe 00000000`03d2db40 : tcl85t!Tcl_ExprObj+0x61c
00000000`03d2dad0 00000000`6a5d2acd : 00000000`03d2dc08 00000000`00000003 00000000`025bf6b0 00000000`0b7c3540 : tcl85t!TclEvalObjEx+0x3ad
00000000`03d2db40 000007fe`e495fddb : 00000000`0a31c8c0 00000000`00312e80 00000000`00312e80 00000000`025fd230 : tcl85t!Tcl_EvalObjEx+0x1d
00000000`03d2db80 00000000`6a5d11fc : 00000000`025bf6b0 00000000`025bf6b0 00000000`0bd8e850 00000000`6a69ac3c : librdi_commontasks+0x1fddb
00000000`03d2dc00 00000000`6a5d218e : 00000000`00000000 00000000`00000003 00000000`025e3890 00000000`0bd8eebe : tcl85t!Tcl_ListMathFuncs+0x58c
00000000`03d2dcb0 00000000`6a656a82 : 00000000`025bf6b0 00000000`0bd8eebe 00000000`00000003 00000000`00000003 : tcl85t!Tcl_EvalEx+0x99e
00000000`03d2dde0 00000000`6a5d1d94 : 00000000`025bf6b0 00000000`00000002 00000000`00000001 00000000`00000000 : tcl85t!Tcl_SubstObj+0x832
00000000`03d2de90 00000000`6a63b660 : 00000000`025bf6b0 00000000`0bd8e850 00000000`00000002 00000000`00000002 : tcl85t!Tcl_EvalEx+0x5a4
00000000`03d2dfc0 000007fe`e4980383 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : tcl85t!Tcl_FSEvalFileEx+0x250
00000000`03d2e070 000007fe`e497f83c : 000007fe`de9e6618 00000000`0977e328 00000000`025bf6b0 00004c8b`36800327 : librdi_commontasks+0x40383
00000000`03d2e290 000007fe`de5ce331 : 00000000`03d2e638 00000000`00240000 00000000`03d2e638 00000000`0024c280 : librdi_commontasks+0x3f83c
00000000`03d2e2c0 000007fe`de5d10f6 : 00000000`025bf6b0 00000000`03d2e638 ffffffff`ffffffff 00000000`00240000 : librdi_common!hdi::tcltasks::task_manager::eval_in_tcl_throw+0x261
00000000`03d2e610 00000000`6a5d11fc : 00000000`00000000 00000000`03d2ea49 00000000`00000000 00000000`025bf6b0 : librdi_common!hdi::tcltasks::task_manager::retrieve_except_msg_instance+0x4c6
00000000`03d2e800 00000000`6a5d1681 : 00005918`00000000 00000000`00000003 00000000`0b7dbd90 00000000`00000000 : tcl85t!Tcl_ListMathFuncs+0x58c
00000000`03d2e8b0 00000000`6a5d2c37 : 00000000`025bb590 00000000`00000003 00000000`00000002 00000000`03d2ea49 : tcl85t!Tcl_EvalObjv+0x51
00000000`03d2e900 00000000`6a5d2acd : 00000000`025bb590 00000000`03d2ea49 00000000`025bf6b0 00000000`00000001 : tcl85t!TclEvalObjEx+0x157
00000000`03d2e970 000007fe`e49b299f : 00000000`025bb590 00000000`00000000 00000000`03d2ead8 00000000`03d2ea01 : tcl85t!Tcl_EvalObjEx+0x1d
00000000`03d2e9b0 000007fe`e49b2b3e : 00000000`0a31bc00 00000000`0a31c590 00000000`0a31bc00 00000000`00000000 : librdi_commontasks!Java_ui_frmwork_commandi_undo+0x2259f
00000000`03d2eab0 000007fe`e49a86ea : 000007fe`e4d4e318 00000000`00000000 00000000`0a31bc00 00000000`00000000 : librdi_commontasks!Java_ui_frmwork_commandi_undo+0x2273e
00000000`03d2eb60 000007fe`e49a8ab7 : 00000000`00000002 00000000`00000008 00000000`00000008 00000000`0000000d : librdi_commontasks!Java_ui_frmwork_commandi_undo+0x182ea
00000000`03d2eda0 000007fe`de5ce331 : 00000000`02671fa0 00000000`00240000 00000000`03d2f1b8 00000000`0024c280 : librdi_commontasks!Java_ui_frmwork_commandi_undo+0x186b7
00000000`03d2ee40 000007fe`de5d10f6 : 00000000`025bf6b0 00000000`03d2f1b8 ffffffff`ffffffff 5f736b73`61746e6f : librdi_common!hdi::tcltasks::task_manager::eval_in_tcl_throw+0x261
00000000`03d2f190 00000000`6a5d11fc : 00000000`006c6374 00000000`03d2f3e0 00005d35`3691900d 00000000`00000001 : librdi_common!hdi::tcltasks::task_manager::retrieve_except_msg_instance+0x4c6
00000000`03d2f380 00000000`6a5d1681 : 00000000`00000000 00000000`0000000d 00000000`025f4660 00000000`00000000 : tcl85t!Tcl_ListMathFuncs+0x58c
00000000`03d2f430 00000000`6a5d2c37 : 00000000`025bc190 00000000`0000000d 00000000`00000001 00000000`03d2f5c9 : tcl85t!Tcl_EvalObjv+0x51
00000000`03d2f480 00000000`6a5d2acd : 00000000`002f90c0 00000000`03d2f5c9 00000000`002f90c0 00000000`025bf6b0 : tcl85t!TclEvalObjEx+0x157
00000000`03d2f4f0 000007fe`ed5946aa : 00000000`0000000c 00000000`00000000 00000000`00000060 00000000`025b82c0 : tcl85t!Tcl_EvalObjEx+0x1d
00000000`03d2f530 00000000`6a646be1 : 00000000`025bb650 00000000`025bb650 00000000`025bf6b0 00000000`00000000 : librdi_commonmain+0x46aa
00000000`03d2f630 000007fe`de5fc0c9 : 00000000`00325b40 00000000`00000000 00000000`00000000 00000000`00000000 : tcl85t!Tcl_Main+0x471
00000000`03d2f890 000007fe`f3eabeed : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`002fca20 : librdi_common!HCTNativeThread::join+0x39
00000000`03d2f8c0 00000000`774c59cd : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : ucrtbase!thread_start<unsigned int (__cdecl*)(void * __ptr64)>+0x5d
00000000`03d2f8f0 00000000`775fa561 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : kernel32!BaseThreadInitThunk+0xd
00000000`03d2f920 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : ntdll!RtlUserThreadStart+0x1d
Re: Vivado 2018.1 Abnormal program termination (EXCEPTION_ACCESS_VIOLATION) during routing
@ugface, the tools should never fail in this manner. Are you able to submit a test case that would enabled me to investigate this issue internally?
Visitor ugface
Since a routed checkpoint was written, I could even write a bit file from it. But the tool indeed failed during final DRC or STA analysis after routing.
I can not provide you the project file. But I will show you the last few lines of log before crash.
INFO: [Timing 38-35] Done setting XDC timing constraints.
WARNING: [Timing 38-3] User defined clock exists on pin XXXXXXXXXXXXX/bufg_rxclk/O and will prevent any subsequent automatic derivation of generated clocks on that pin. If the user defined clock specifies '-add', any existing auto-derived clocks on that pin are retained.
WARNING: [Timing 38-3] User defined clock exists on pin XXXXXXXXX/bufg_txclk/O and will prevent any subsequent automatic derivation of generated clocks on that pin. If the user defined clock specifies '-add', any existing auto-derived clocks on that pin are retained.
Please check '....../impl_2/hs_err_pid6344.log' for details
@ugface, without being able to reproduce the issue locally, there's not a lot that can be done. Can you upload hs_err_pid6344.log and the corresponding .dmp file?
With regards to Abnormal program terminations, see AR# 55854.
Visitor ugface
FYI, here're the log and dump files.
Thanks @ugface, I'll see if any information can be extracted from the .dmp file. Can you also upload the runme.log from impl_2 directory which shows exactly where in the flow the issue occurs?
Visitor ugface
Hi, peadard, I don't have the rume.log file now, since I reverted the project to Vivado 2017.3. I think you can locate source file locations of the bug from the dmp file. It's obviously a problem of referencing a NULL pointer.
