[Vivado 2018.1] An unexpected error has occurred (11)
Hi, while running P&R I got a crash. The context behind this is that I am attempting to install the Xilinx 1G Ethernet PCS/PMA IP. When I connect the sgmii_clk output from the IP to our MAC (this clock is derived from an external differential 125Mhz gtrefclk):
# An unexpected error has occurred (11)
Stack:
/lib64/libc.so.6(+0x32510) [0x7ffff5f5f510]
/global/cust_apps/vivado_2018.1/Vivado/2018.1/lib/lnx64.o/librdi_netlist.so(HDLHBusInstTermBit::getBusInstTermLH() const+0x1) [0x7fffc82b3f91]
/global/cust_apps/vivado_2018.1/Vivado/2018.1/lib/lnx64.o/librdi_netlist.so(HDLHBusInstTermBit::getInstanceLH() const+0x9) [0x7fffc82b4119]
/global/cust_apps/vivado_2018.1/Vivado/2018.1/lib/lnx64.o/librdi_timing.so(HAST3TimeAhead::getStaleInstDelays(HSTPtrHashMap<HDLHInstance const, HSTVector<sta::Edge*, std::allocator<sta::Edge*> >*>&)+0x22b) [0x7fffc195052b]
/global/cust_apps/vivado_2018.1/Vivado/2018.1/lib/lnx64.o/librdi_timing.so(HAST3TimeAhead::updateStaleDelays()+0x1a2) [0x7fffc1951bc2]
/global/cust_apps/vivado_2018.1/Vivado/2018.1/lib/lnx64.o/librdi_timing.so(HAST3TimeAhead::updateDelays(HDGUIStatus*, HASTUpdateTimingParams const&)+0x76) [0x7fffc1951f56]
/global/cust_apps/vivado_2018.1/Vivado/2018.1/lib/lnx64.o/librdi_timing.so(HAST3TimeAhead::updateTiming1(HASTUpdateTimingParams const&, HDGUIStatus*)+0x2ae) [0x7fffc19578be]
/global/cust_apps/vivado_2018.1/Vivado/2018.1/lib/lnx64.o/librdi_timing.so(HAST3TimeAhead::updateTiming(HASTUpdateTimingParams const&, HDGUIStatus*)+0x4a0) [0x7fffc19582f0]
/global/cust_apps/vivado_2018.1/Vivado/2018.1/lib/lnx64.o/librdi_implflow.so(HAPSTimingMgr::updateDelays(bool)+0xb8) [0x7fffcb50bfb8]
/global/cust_apps/vivado_2018.1/Vivado/2018.1/lib/lnx64.o/librdi_implflow.so(HAPSPlaceMgrBase::setupTiming()+0x9e) [0x7fffcb4c118e]
/global/cust_apps/vivado_2018.1/Vivado/2018.1/lib/lnx64.o/librdi_implflow.so(HAPSPlaceMgr::incrPlace(HAPSPlaceMgrPlaceConfig)+0x130) [0x7fffcb4b9190]
/global/cust_apps/vivado_2018.1/Vivado/2018.1/lib/lnx64.o/librdi_implflow.so(HAPSPlaceMgr::place(HAPSPlaceMgrPlaceConfig)+0x8b) [0x7fffcb4baedb]
/global/cust_apps/vivado_2018.1/Vivado/2018.1/lib/lnx64.o/librdi_implflow.so(HAPSOptBase::incrPlace(HAPSPlaceMgrPlaceConfig)+0x72) [0x7fffcb6736a2]
/global/cust_apps/vivado_2018.1/Vivado/2018.1/lib/lnx64.o/librdi_implflow.so(HAPSPathLenReduct::optimizeSingleNet(HAPSTimingPath&, HAPSNet*, HDLHElement const*&, bool*)+0x2980) [0x7fffcb6a3cd0]
/global/cust_apps/vivado_2018.1/Vivado/2018.1/lib/lnx64.o/librdi_implflow.so(HAPSFlow::performOptsOnOneNet(HAPSTimingPath&, HDLHNet*, HDLHElement const*&)+0x61f) [0x7fffcb60547f]
/global/cust_apps/vivado_2018.1/Vivado/2018.1/lib/lnx64.o/librdi_implflow.so(HAPSFlow::callPathBasedOpts()+0x1cb5) [0x7fffcb608bb5]
/global/cust_apps/vivado_2018.1/Vivado/2018.1/lib/lnx64.o/librdi_implflow.so(HAPSFlow::optimize()+0x6e8) [0x7fffcb616678]
/global/cust_apps/vivado_2018.1/Vivado/2018.1/lib/lnx64.o/librdi_vivadotasks.so(PhysOptDesignTclTask::phys_opt_design::executeClient()+0xdcd) [0x7fffb42df24d]
/global/cust_apps/vivado_2018.1/Vivado/2018.1/lib/lnx64.o/librdi_vivadotasks.so(PhysOptDesignTclTask::phys_opt_design::execute_()+0x662) [0x7fffb42dfcd2]
/global/cust_apps/vivado_2018.1/Vivado/2018.1/lib/lnx64.o/librdi_vivadotasks.so(PhysOptDesignTclTask::phys_opt_design::execute()+0x96) [0x7fffb42e0246]
/global/cust_apps/vivado_2018.1/Vivado/2018.1/lib/lnx64.o/librdi_common.so(+0x778822) [0x7ffff71da822]
/global/cust_apps/vivado_2018.1/Vivado/2018.1/lib/lnx64.o/libtcl8.5.so(+0x334af) [0x7ffff17434af]
/global/cust_apps/vivado_2018.1/Vivado/2018.1/lib/lnx64.o/libtcl8.5.so(+0x34b38) [0x7ffff1744b38]
/global/cust_apps/vivado_2018.1/Vivado/2018.1/lib/lnx64.o/libtcl8.5.so(Tcl_EvalEx+0x13) [0x7ffff17450a3]
/global/cust_apps/vivado_2018.1/Vivado/2018.1/lib/lnx64.o/libtcl8.5.so(Tcl_FSEvalFileEx+0x1da) [0x7ffff17a9c5a]
/global/cust_apps/vivado_2018.1/Vivado/2018.1/lib/lnx64.o/librdi_commontasks.so(+0x1cf79d) [0x7fffe674c79d]
/global/cust_apps/vivado_2018.1/Vivado/2018.1/lib/lnx64.o/libtcl8.5.so(Tcl_EvalObjv+0x32) [0x7ffff17435e2]
/global/cust_apps/vivado_2018.1/Vivado/2018.1/lib/lnx64.o/libtcl8.5.so(TclEvalObjEx+0x322) [0x7ffff1745402]
/global/cust_apps/vivado_2018.1/Vivado/2018.1/lib/lnx64.o/librdi_commontasks.so(+0x200ddf) [0x7fffe677dddf]
/global/cust_apps/vivado_2018.1/Vivado/2018.1/lib/lnx64.o/librdi_commontasks.so(+0x2024ae) [0x7fffe677f4ae]
/global/cust_apps/vivado_2018.1/Vivado/2018.1/lib/lnx64.o/librdi_commonmain.so(+0x7414) [0x7ffff685e414]
/global/cust_apps/vivado_2018.1/Vivado/2018.1/lib/lnx64.o/libtcl8.5.so(Tcl_Main+0x1d0) [0x7ffff17b0210]
/global/cust_apps/vivado_2018.1/Vivado/2018.1/lib/lnx64.o/librdi_common.so(+0x7bb82b) [0x7ffff721d82b]
/lib64/libpthread.so.0(+0x7aa1) [0x7ffff5d17aa1]
/lib64/libc.so.6(clone+0x6d) [0x7ffff6015bcd]
The failure is consistent across 3 attempts. SOS!
The closest related issue on the forum that i could find is here on an older version of Vivado: https://www.xilinx.com/support/answers/66489.html but I could not find any IOSTANDARD constraints on the gtrefclk in my build.
@silverace99work
For project mode, Please share the runme.log file present in <project>/<project>.runs/impl_1 folder
For non-project mode, share the vivado.log file.
If possible can you try in 2018.3 and check if it still crashes?
--Syed
@silverace99work,
How are you so sure that the reason is dur to this? What is the argument for saying so?
Also did your design pass function verification via simulation?
FPGA enthusiast!
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer solved your problem.
Hi @Syedz. At this point we moved on by moving the ethernet design to another fpga (we are running on a multi-board acceleration platform) and the problem disappeared. The next time I can find time to reproduce the logs, I will do so. Startup life is manic. If in the meantime you would like me to somehow "close" this issue for the moment, please let me know how.
@Anonymous : The single change where I connected the sgmii_clk from the IP to the MAC resulted in this tool crash. If I undo it, the problem goes away. Yes design passes sims.
Thank you for the replies.
