dmzehnder
Vivado 2018.3 Abnormal program termination (EXCEPTION_ACCESS_VIOLATION)
I ge the following error in Vivado 2018.3
Please check 'C:/..../hs_err_pid4612.log' for details
hs_err_pid4612.log:
# An unexpected error has occurred (EXCEPTION_ACCESS_VIOLATION)
Stack:
no stack trace available, please use hs_err_<pid>.dmp instead.
Why?
rshekhaw
Hi @dmzehnder ,
It is actually Vivado getting crashed. Please chec the below link of an AR# for more infomation:
https://www.xilinx.com/support/answers/55854.html
Also can you please let us know in which phase it is getting crashed?
Please if possible can you please try the latest Vivado 2019.1 version and check whether the crash is still persisting?
Raj
syedz
@dmzehnder
Any update on this thread? If the above shared information was not helpful then please share the vivado.log, crash log files and xifno.txt file.
Run below command from Vivado TCL console and share generated xinfo.txt file.
report_environment -file xinfo.txt
--Syed
schulz.s
are there any update on this thread?
We have the same Problem with Vivado 2018.3 and Windows 10. We implemented the design with 2019.1 and it was passed thru.
The problem is, at the moment we cannot switch to Vivado 2019.1 because the project is at an advanced stage and
we don't want to add other problems with the switch.
So, are there other solutions for Vivado 2018.3?
syedz
@schulz.s
Can you share the vivado.log, crash log file and xinfo.txt mentioned in my previous post above.
--Syed
schulz.s
@syedz
Of course, but I must remove some parts (company confidantial) from the files.
acajic
 Any progress here? I am having the same issue on Vviado 2018.1 during implementation.
schulz.s
Hello acajic,
no, unfortunately there is nothing new....
We have switched to a new version (2019.1/2020.2) of Vivado, where the problem no longer occurs.
Best Steven.
