Vivado Block design Clock error
Hi Team,
I Tried to design a block design using vivado 2014.2 design suite for reading a video from an RGB camera. but it shows error in pixel clock section. but i am not able to solve this clock config error. i am attaching the error details.
please help me to solve issues
How i can solve this issue.
is there any issue in connection of Video In to AXI Stream block design.
Yours Faithfully,
Shankar
Hi @Shankar,
By looking at your XDC file and the error description, I believe the problem is due to the input and output pins have not been assigned a physical pin.
Since Vivado does not know in which bank and physical pin those ports should be placed, it ends up throwing a "Failed to Place" error.
Please review the document Vivado I/O and Clock Planning - UG899, specially the part Placing I/O Ports, pg. 42.
Andre Guerrero
Product Applications Engineer
