dppwrightdl
Vivado HLx: 2019x - place_design - Abnormal program termination (11)
For a fairly large, but not particularly complex, UltraScale design, Vivado consistently crashes during place_design Phase 1.2 (IO placement, clockplacement, build placer device), under both Linux and Windows.
Please check '/space/local_scratch/dwright/work/git/navarro_soc/dut/asic/hs_err_pid153371.log' for details
Tried both 2019.1 and 2019.2 (2018.3 hangs during synthesis gated clock conversion)
CentOS Linux release 7.6.1810 (Core)
The Linux log is below. Can someone help please, as this is seriously blocking our FPGA program.
# An unexpected error has occurred (11)
Stack:
/usr/lib64/libc.so.6(+0x36280) [0x7f8b46a66280]
/projects/edatools/ictools/xilinx/Vivado/2019.2/lib/lnx64.o/libCOIN-all.so(CoinFactorization::updateColumnTransposeLSparse(CoinIndexedVector*) const+0x125) [0x7f8b4614da25]
/projects/edatools/ictools/xilinx/Vivado/2019.2/lib/lnx64.o/libCOIN-all.so(CoinFactorization::updateColumnTranspose(CoinIndexedVector*, CoinIndexedVector*) const+0x16f) [0x7f8b4614fa4f]
/projects/edatools/ictools/xilinx/Vivado/2019.2/lib/lnx64.o/libCOIN-all.so(ClpFactorization::updateColumnTranspose(CoinIndexedVector*, CoinIndexedVector*) const+0x39) [0x7f8b46012559]
/projects/edatools/ictools/xilinx/Vivado/2019.2/lib/lnx64.o/libCOIN-all.so(ClpSimplex::computeDuals(double*)+0x569) [0x7f8b46089c49]
/projects/edatools/ictools/xilinx/Vivado/2019.2/lib/lnx64.o/libCOIN-all.so(ClpSimplex::gutsOfSolution(double*, double const*, bool)+0x309) [0x7f8b4609fd99]
/projects/edatools/ictools/xilinx/Vivado/2019.2/lib/lnx64.o/libCOIN-all.so(ClpSimplexDual::statusOfProblemInDual(int&, int, double*, ClpDataSave&, int)+0x672) [0x7f8b460b3b42]
/projects/edatools/ictools/xilinx/Vivado/2019.2/lib/lnx64.o/libCOIN-all.so(ClpSimplexDual::fastDual(bool)+0x228) [0x7f8b460b7ef8]
/projects/edatools/ictools/xilinx/Vivado/2019.2/lib/lnx64.o/libCOIN-all.so(OsiClpSolverInterface::solveFromHotStart()+0xe8c) [0x7f8b4611b76c]
/projects/edatools/ictools/xilinx/Vivado/2019.2/lib/lnx64.o/libCOIN-all.so(CbcNode::chooseDynamicBranch(CbcModel*, CbcNode*, OsiSolverBranch*&, int)+0x1a1d) [0x7f8b45eb264d]
/projects/edatools/ictools/xilinx/Vivado/2019.2/lib/lnx64.o/libCOIN-all.so(CbcModel::chooseBranch(CbcNode*&, int, CbcNode*, OsiCuts&, bool&, CoinWarmStartBasis*, double const*, double const*, OsiSolverBranch*&)+0x6ea) [0x7f8b45e9b16a]
/projects/edatools/ictools/xilinx/Vivado/2019.2/lib/lnx64.o/libCOIN-all.so(CbcModel::doOneNode(CbcModel*, CbcNode*&, CbcNode*&)+0x188a) [0x7f8b45ea261a]
/projects/edatools/ictools/xilinx/Vivado/2019.2/lib/lnx64.o/libCOIN-all.so(CbcModel::branchAndBound(int)+0x2063) [0x7f8b45ea5533]
/projects/edatools/ictools/xilinx/Vivado/2019.2/lib/lnx64.o/librdi_common.so(HUCOINWrapper::generateOptimalSolution()+0x5e) [0x7f8b47e7091e]
/projects/edatools/ictools/xilinx/Vivado/2019.2/lib/lnx64.o/librdi_common.so(HUCOINWrapper::doSolve(bool)+0xa8) [0x7f8b47e71348]
/projects/edatools/ictools/xilinx/Vivado/2019.2/lib/lnx64.o/librdi_common.so(HULPInterfaceCOIN::getIntegerSolution(bool)+0x47) [0x7f8b47e7eaa7]
/projects/edatools/ictools/xilinx/Vivado/2019.2/lib/lnx64.o/librdi_place.so(HAISioClkSolver::solveILPModel()+0x805) [0x7f8b0c66ef55]
/projects/edatools/ictools/xilinx/Vivado/2019.2/lib/lnx64.o/librdi_place.so(HAPIPlacer::placeIOs(HAPIPlacer::Param const&)+0x2b3) [0x7f8b0c0eb9f3]
/projects/edatools/ictools/xilinx/Vivado/2019.2/lib/lnx64.o/librdi_place.so(HAPIAutoTermPlaceApi2::RunIOPlacer(bool, HSTVector<HDLHTerminal const*, std::allocator<HDLHTerminal const*> > const&, HSTVector<HDLHTerminal const*, std::allocator<HDLHTerminal const*> >&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const*)+0x3276) [0x7f8b0bfc08e6]
/projects/edatools/ictools/xilinx/Vivado/2019.2/lib/lnx64.o/librdi_place.so(HAPIAutoTermPlaceApi2::canPlaceClocksAndTerms(HDPLLocSet&, HSTVector<HDLHTerminal const*, std::allocator<HDLHTerminal const*> > const&, HSTVector<HDLHTerminal const*, std::allocator<HDLHTerminal const*> >&, bool&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&, bool, bool&, bool, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const*)+0x5a) [0x7f8b0bfc8d0a]
/projects/edatools/ictools/xilinx/Vivado/2019.2/lib/lnx64.o/librdi_place.so(HAPLFFlowInitializer::placeIOClock(HDPLLocSet&, HSTVector<HDLHTerminal const*, std::allocator<HDLHTerminal const*> >&, HSTVector<HDLHTerminal const*, std::allocator<HDLHTerminal const*> >&, HAPIAutoTermPlaceApi2&, bool&, bool&, bool, bool, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const*)+0x20b) [0x7f8b0cce942b]
/projects/edatools/ictools/xilinx/Vivado/2019.2/lib/lnx64.o/librdi_place.so(+0x1c80023) [0x7f8b0cceb023]
/projects/edatools/ictools/xilinx/Vivado/2019.2/lib/lnx64.o/Default/libgomp.so.1(+0x15c66) [0x7f8b404dfc66]
/usr/lib64/libpthread.so.0(+0x7dd5) [0x7f8b4681bdd5]
/usr/lib64/libc.so.6(clone+0x6d) [0x7f8b46b2dead]
syedz
@dppwrightdl
For workaround, Did you try using different placer directives? Also, try disabling multithreading before implementation by running the following command:
set_param general.maxThreads 1
The expectation from the tool is to never crash. If you can share the post opt dcp file then I will report this to the factory to get it fixed.
I have sent you an email from ezmove (ftp) to share the files.
--Syed
syedz
@dppwrightdl
To debug the issue, Can you please share the following files:
  1. Crash log files. https://www.xilinx.com/support/answers/55854.html
  2. Vivado.log file
  3. Run the following command from TCL console which will generate xinfo.txt file which has your system environment related information:
    1. report_environment ./xinfo.txt
    2. type pwd to know the location where the file is generated.
--Syed
