Vivado [Place 30-675] issue
Hello
Running vivado to P&R will report error message:
But my constraint configure GCIO, why vivado report this error message?
How to resolve this issue?
Vivado: 2017.2
 FPGA device: VU440FLGA2892-1-c
Constraint:
set_property PACKAGE_PIN AF49 [get_ports {XSYS_CLK_0}]
set_property PACKAGE_PIN AF48 [get_ports {XSYS_CLK}]
Vivado Log:
INFO: [Timing 38-35] Done setting XDC timing constraints.
ERROR: [Place 30-675] Sub-optimal placement for a global clock-capable IO pin and BUFG pair.If this sub optimal condition is acceptable for this design, you may use the CLOCK_DEDICATED_ROUTE constraint in the .xdc file to demote this message to a WARNING. However, the use of this override is highly discouraged. These examples can be used directly in the .xdc file to override this clock rule.
        < set_property CLOCK_DEDICATED_ROUTE FALSE [get_nets SYS_CLK_ibufgds/O] >
        SYS_CLK_ibufgds/IBUFCTRL_INST (IBUFCTRL.O) is locked to IOB_X0Y281 (in SLR 1)
        The loads are distributed to 1 user pblock constraints. In addition, there are 20 loads not in user pblock constraints.
        Displaying only the first 20 or fewer instances under each constraint as list of loads is too long
 Displaying first 20 loads not in user pblock constraint:
../u_global/u_gating/u_clock_gate_global_ram/U_CLKGATE (BUFGCE.I) is provisionally placed by clockplacer on BUFGCE_X0Y116 (in SLR 0)
../u_global/u_gating/u_clock_gate_global/U_CLKGATE (BUFGCE.I) is provisionally placed by clockplacer on BUFGCE_X0Y117 (in SLR 0)
../stack0.u_sc_stack_0/tile0.u_sc_tile0/u_shader_tile_gating/u_clock_gate_sc/U_CLKGATE (BUFGCE.I) is provisionally placed by clockplacer on BUFGCE_X0Y118 (in SLR 0)
../cg.u_cg_async/u_core_group/u_gating/stack0.u_clock_gate_stack0_stack/U_CLKGATE (BUFGCE.I) is provisionally placed by clockplacer on BUFGCE_X0Y138 (in SLR 1)
../cg.u_cg_async/u_core_group/u_gating/u_clock_gate_mmu/U_CLKGATE (BUFGCE.I) is provisionally placed by clockplacer on BUFGCE_X0Y140 (in SLR 1)
../cg.u_cg_async/u_core_group/u_gating/u_clock_gate_tiler_ram/U_CLKGATE (BUFGCE.I) is provisionally placed by clockplacer on BUFGCE_X0Y119 (in SLR 0)
../cg.u_cg_async/u_core_group/u_gating/u_clock_gate_tiler/U_CLKGATE (BUFGCE.I) is provisionally placed by clockplacer on BUFGCE_X0Y143 (in SLR 1)
../cg.u_cg_async/u_core_group/u_gating/u_clock_gate_pmb_ram/U_CLKGATE (BUFGCE.I) is provisionally placed by clockplacer on BUFGCE_X0Y142 (in SLR 1)
../cg.u_cg_async/u_core_group/u_gating/u_clock_gate_pmb/U_CLKGATE (BUFGCE.I) is provisionally placed by clockplacer on BUFGCE_X0Y141 (in SLR 1)
../cg.u_cg_async/u_core_group/u_gating/clock_gate_l20.gen_l20_ram[11].cond_ram.u_clock_gate_l2_0_ram/U_CLKGATE (BUFGCE.I) is provisionally placed by clockplacer on BUFGCE_X0Y122 (in SLR 1)
../cg.u_cg_async/u_core_group/u_gating/clock_gate_l20.gen_l20_ram[4].cond_ram.u_clock_gate_l2_0_ram/U_CLKGATE (BUFGCE.I) is provisionally placed by clockplacer on BUFGCE_X0Y130 (in SLR 1)
../cg.u_cg_async/u_core_group/u_gating/clock_gate_l20.gen_l20_ram[12].cond_ram.u_clock_gate_l2_0_ram/U_CLKGATE (BUFGCE.I) is provisionally placed by clockplacer on BUFGCE_X0Y123 (in SLR 1)
../cg.u_cg_async/u_core_group/u_gating/clock_gate_l20.gen_l20_ram[1].cond_ram.u_clock_gate_l2_0_ram/U_CLKGATE (BUFGCE.I) is provisionally placed by clockplacer on BUFGCE_X0Y128 (in SLR 1)
../cg.u_cg_async/u_core_group/u_gating/clock_gate_l20.gen_l20_ram[8].cond_ram.u_clock_gate_l2_0_ram/U_CLKGATE (BUFGCE.I) is provisionally placed by clockplacer on BUFGCE_X0Y134 (in SLR 1)
../cg.u_cg_async/u_core_group/u_gating/clock_gate_l20.gen_l20_ram[7].cond_ram.u_clock_gate_l2_0_ram/U_CLKGATE (BUFGCE.I) is provisionally placed by clockplacer on BUFGCE_X0Y133 (in SLR 1)
../cg.u_cg_async/u_core_group/u_gating/clock_gate_l20.gen_l20_ram[13].cond_ram.u_clock_gate_l2_0_ram/U_CLKGATE (BUFGCE.I) is provisionally placed by clockplacer on BUFGCE_X0Y124 (in SLR 1)
../cg.u_cg_async/u_core_group/u_gating/clock_gate_l20.gen_l20_ram[6].cond_ram.u_clock_gate_l2_0_ram/U_CLKGATE (BUFGCE.I) is provisionally placed by clockplacer on BUFGCE_X0Y132 (in SLR 1)
../cg.u_cg_async/u_core_group/u_gating/clock_gate_l20.gen_l20_ram[0].cond_ram.u_clock_gate_l2_0_ram/U_CLKGATE (BUFGCE.I) is provisionally placed by clockplacer on BUFGCE_X0Y120 (in SLR 1)
../cg.u_cg_async/u_core_group/u_gating/clock_gate_l20.gen_l20_ram[9].cond_ram.u_clock_gate_l2_0_ram/U_CLKGATE (BUFGCE.I) is provisionally placed by clockplacer on BUFGCE_X0Y135 (in SLR 1)
../cg.u_cg_async/u_core_group/u_gating/clock_gate_l20.gen_l20_ram[15].cond_ram.u_clock_gate_l2_0_ram/U_CLKGATE (BUFGCE.I) is provisionally placed by clockplacer on BUFGCE_X0Y126 (in SLR 1)
Displaying the first 8 loads for pblock constraint 1
../cg.u_cg_async/u_core_group/u_gating/clock_gate_l20.gen_l20_ram[10].cond_ram.u_clock_gate_l2_0_ram/U_CLKGATE (BUFGCE.I) is provisionally placed by clockplacer on BUFGCE_X0Y121 (in SLR 1)
../cg.u_cg_async/u_core_group/u_gating/clock_gate_l20.gen_l20_ram[14].cond_ram.u_clock_gate_l2_0_ram/U_CLKGATE (BUFGCE.I) is provisionally placed by clockplacer on BUFGCE_X0Y125 (in SLR 1)
../cg.u_cg_async/u_core_group/u_gating/clock_gate_l20.gen_l20_ram[3].cond_ram.u_clock_gate_l2_0_ram/U_CLKGATE (BUFGCE.I) is provisionally placed by clockplacer on BUFGCE_X0Y129 (in SLR 1)
../cg.u_cg_async/u_core_group/u_gating/clock_gate_l20.gen_l20_ram[16].cond_ram.u_clock_gate_l2_0_ram/U_CLKGATE (BUFGCE.I) is provisionally placed by clockplacer on BUFGCE_X0Y127 (in SLR 1)
../cg.u_cg_async/u_core_group/u_gating/clock_gate_l20.gen_l20_ram[5].cond_ram.u_clock_gate_l2_0_ram/U_CLKGATE (BUFGCE.I) is provisionally placed by clockplacer on BUFGCE_X0Y131 (in SLR 1)
../cg.u_cg_async/u_core_group/u_gating/clock_gate_l20.u_clock_gate_l2_0_ramif/U_CLKGATE (BUFGCE.I) is provisionally placed by clockplacer on BUFGCE_X0Y137 (in SLR 1)
../cg.u_cg_async/u_core_group/u_gating/clock_gate_l20.u_clock_gate_l2_0/U_CLKGATE (BUFGCE.I) is provisionally placed by clockplacer on BUFGCE_X0Y136 (in SLR 1)
../cg.u_cg_async/u_core_group/u_gating/u_clock_gate_cg/U_CLKGATE (BUFGCE.I) is provisionally placed by clockplacer on BUFGCE_X0Y139 (in SLR 1)
Re: Vivado [Place 30-675] issue
Hello @syedz @marcb
This issue is my design used 171 BUFG, so vivado can't placement complete and report this error message.
Reduce design BUFG can resolve this issue.
@quincyq2003,
Can you share the location of IO and BUFG? Please see the following answer record:
https://www.xilinx.com/support/answers/66659.html
--Syed
Hello @syedz
IO location is IOB_X0Y281
BUFG is BUFGCE_X0Y124
@quincyq2003,
The IO is clock capable (GCIO) and also the BUFG is in same clock region (X0Y5).
Can you share the post opt dcp file to debug the issue?
--Syed
Hello @syedz
I can't share the dcp for you.
Could you provide resolve method, may be i can resolve this issue.
Hi @quincyq2003. Is the full log file as well as the physical constraints related to the clock path and pblocks available? A simple test using the same primitives, connectivity, and placement did not reproduce.
Hello @marcb@syedz
This issue is resolve.
Thanks for your help!!
@quincyq2003,
Thanks for the update. Can you please share the solution so that it will help other user facing the same issue.
Also please close this thread by marking the post which helped as "Accept as Solution"
--Syed
Hello @syedz @marcb
