Visitor andreastepe
Vivado Select Hardware Target
Hello!
I'm sure, the information I'm looking for is somewhere hidden here but after seraching for it the whole day (yepp...), I'm giving up now and hope you can point me towards it.
I have the newest Vivado suite installed. It doesn't tell me which option, but I added a licence key for the option two steps above the WEBPack version.
The board I'm working with is HW-Z7-ZC702 Rev. 1.1
This is my problem: I have successfully generated a bitstream in Vivado and would like to implement it on the Zync FPGA on the board via the Digilent programmer interface that is implemented on the ZC702.
So I opened the "Open Target" option in the Hardware Manager chose Server Name localhost:50001 (because on 60001 nothing was listening) and got the window of which I attached a screenshot. This window is completely inert. I can't do anything but "Back" and "Cancel".
I was now trying to find out how to add something to the hardware server so that my board is recognized, but I could not find any information in this forum, in the Xilinx documents or with google.
I even tried the same thing on Linux but with the same non-interactive window. What am I doing wrong?
Thanks a lot for your help!
Cheers,
Andreas
PS.: This is the first time in my life that I try programming an FPGA. So my guess is, I simply don't know what exactly to search for.
Visitor andreastepe
Re: Vivado Select Hardware Target
Hello again!
I'm successful now!
This is what was wrong:
The default value for SW16 should be 00000 (all switches to the left). This is enabling the standard JTAG mode. On my board every second switch was 1 (left). This is a not defined state. Setting the switches correctly makes everything run smoothly.
Btw.: Vivado now also works under Linux (Debian Jessie) for me! :)
Thanks for your help!
Cheers,
Andreas
I think your board is detected & you have to click on drop down list.
 Check the below snapshot:-
Please try & let us know the update.
Harry
Have you referred to ZC702 HW user guide. Here are some points to consider.
The JTAG chain can be programmed by three different methods made available via a 3-to-1 analog switch (U75, U76, and U77) controlled by a 2-position DIP switch at SW10.
DIP switch SW10 setting 01 selects the 14-pin header J2 for configuration using either a Parallel Cable IV (PC4) or Platform Cable USB II.
DIP switch SW10 setting 10 selects the USB-to-JTAG Digilent bridge U23 for configuration over a Standard-A to Micro-B USB cable.
DIP switch SW10 setting 11 selects the JTAG 20-pin header at J58.
Visitor andreastepe
Hello!
Thanks for your answer!
When I click onto that field, I get a little arrow up/down, but there are no devices in the list below. Nothing changes.
Cheers,
Andreas
Visitor andreastepe
Hello venkata,
I checked the switch and it was set to
Pos  1  2
Val on off
as default value. I just played around with it to make sure the high and low bit are what I thought they are, but that does not change anything.
So, no success so far.
Cheers,
Andreas
Visitor andreastepe
Hello again!
I'm successful now!
Cheers,
Andreas
Visitor andreastepe
One more thing: The description for switch SW10 on the board says:
10: Plattform USB
01: Digilent
11: JTAG 20-pin
Looking onto SW10 from the direction in which you can read the description (description is above the power connector), the correct setting for using U23 Digilent programmer is:
     left (1)       right (2)
  down (off)    up (on)
I was a little confused about what the correct setting is. From my point of view, the manual describes the settings invertedly.
Cheers,
Andreas
Thanks for sharing the solution. It will be helpful for others.
Harry
Thanks andreastepe.
I just spent way too long trying to figure this out. My problem was SW10.
it should be repeated, position one, on the left, needs to be down. Position 2, on the right needs to be up.
