Teacher drjohnsmith
Vivado, USR_ACCESS and axi bus
Using Vovado, in GUI mode,
how can I set the USR_ACCESS = TIMESTAMP property ?
also , I would love to be able to read the USR_ACCESS from the axi bus of the zynq,
     is there a AXi peripheral with the USR_ACCESS timestamp available ,
Teacher muzaffer
Re: Vivado, USR_ACCESS and axi bus
BITSTREAM.CONFIG.USR_ACCESS property is available through the "add property" dialog box of the gui so one can set it there. As to the block instantiation, I think it would be a great idea for Xilinx to make all blocks in the HDL library to be available through the IP integrator.
Teacher muzaffer
you can set the usr_access by:
set_property BITSTREAM.CONFIG.USR_ACCESS TIMESTAMP [current_design] during implementation.
As to reading it, a USR_ACCESSE2 component has to be instantiated in the design but I don't know of any IP which does this for you. It should be quite easy though.
Teacher drjohnsmith
thank you
the company is using the vivado gui,
   can they add tcl set properties commands in the gui.
       with a tcl script mode, yes, but the problme is adding the property to the gui,
as for the component,
   yes, add a gpio axi block, wire that to the User_access block,
        again they are using the gui, so the gpio axi is in the block diagram designer, the USER_access bloxk is in native vhdl,
seems a pity there is not a user-acess block in the ip integrator ,
    ,ight have to make one,, !!
Teacher muzaffer
Teacher drjohnsmith
thank you
will give it a go next week
so who do we pester to get the ip added ? or is that another story ?
have a good weekend
Teacher drjohnsmith
so looking at vivado , 2013.4 make certain we have this tied down.
have project up,
they click project Manager => Project settings
    and on the wondow that pops up, click implimentation and scroill down to write_bitstream
and in the more opotions* box they add
Teacher drjohnsmith
thank you
customer happy with the description,
Scholar dwisehart
This did not work for me.  Vivado 2013.4 gave me this error:
INFO: [Project 1-484] Checkpoint was created with build 353583
open_checkpoint: Time (s): cpu = 00:01:57 ; elapsed = 00:01:48 . Memory (MB): peak = 2307.410 ; gain = 1505.344
ERROR: [Common 17-165] Too many positional options when parsing 'TIMESTAMP', please type 'write_bitstream -help' for usage info.
while executing
"write_bitstream -force FPGA.bit set_property BITSTREAM.CONFIG.USR_ACCESS TIMESTAMP"
INFO: [Common 17-206] Exiting Vivado at Tue Jan 21 07:08:43 2014...
Daniel
Teacher drjohnsmith
which device are you using ?
Scholar dwisehart
xc7vx690tffg1761-2
Teacher muzaffer
command should be entered at the TCL commandline before running "write_bitstream -force FPGA.bit". These are two separate actions. Also the set_property needs an object to which it applies so probably:
would work.
Scholar dwisehart
OK, the previous post said that this was to be set in Bitstream Settings->More Options, but that did not work, as noted.
Putting set_property BITSTREAM.CONFIG.USR_ACCESS TIMESTAMP in the TCL command line did work, but doing that every time before you create a bitfile in the Vivado GUI would be painful.
The first thing I tried that worked is putting this command in the XCF file for the project.
The second thing that worked was creating a TCL script file with just this command in it, and then setting Bitstream Options-> tcl.pre to this filename.
Thanks for the help.
Daniel
Scholar dwisehart
XDC, not UCF or XCF. My bad.
Teacher muzaffer
You're welcome.
Teacher drjohnsmith
what are we using for object ?
I've just tried typing in to tcl
and I get the error
ERROR: [Common 17-163] Missing value for option 'objects',
Please provide default value.
For more info check page 65 http://www.xilinx.com/support/documentation/sw_manuals/xilinx2012_4/ug908-vivado-programming-debugging.pdf
Scholar dwisehart
open_run impl_1
set_property BITSTREAM.CONFIG.USR_ACCESS TIMESTAMP} [get_runs impl_1]
The other option, assuming you have the implementation open:
Teacher drjohnsmith
thank you
I think I forgot the [ ] brackets...
Teacher drjohnsmith
that worked, ta
Visitor tomuon
For reading the timestamp, couldn't you use the AXI HWICAP controller to get at the AXSS config register?  I guess you would have to parse the bitstream during the readback.  XAPP497 seems to allude to this method.
