Vivado: When placing some output Pins it automatically unplaced other completely unrelated pins?
Hallo,
I'm pretty new with Vivado. Experience with ISE but not with Vivado.
I started a new project, I assigned the pins and everything was OK. I wanted to change the assignment and out of the blue when I try to reassign some pins I got the message: "Pins X.... Y ...... are already place and will be unplaced first". This pins/ports are completed unrelated one with each other.
For example. adc_clk1 and adc_clk0 - is the same signal connected to these two external ports (out std_logic)
  • adc_clk0 <= s_adc_clk;
  • adc_clk1 <= s_adc_clk;
When I try to connect adc_clk1 to G17 (Bank 35) vivado wants to unplace all DDR (Zynq Proc) pins from Bank 500 (or something like this).
When I try to connect adc_clk0 to G17 (Bank 35) vivado wants to unplace my LEDS(7-0) pins.
I went with connecting adc_clk0. I started reconnecting again LEDS pins and at LEDS(4) now I get the same problem with completely other pins. It's like a vicious circle.
Please also see the attachment.
What am I doing wrong? Thank you!
Paul
Hi Florent,
You cannot see it in my pictures but I was already in the Synthesized Design (I checked it once more by 'uncropping' the screenshots attached to my post).
It works now. I didn't change it under I/O Ports Design (window in the lower part) but under Device Constrains/ I/O Bank 35 / G17 I assigned adc_clk_0. It worked. After a complete flow: Synthesize, Implementation & Generate Bitstream I tried again to change under I/O Ports Design and it works.
Have no idea if I did something wrong??
Paul
Hi @paul.tutzu,
You may want to try to change the port locations on the synthesized design (not in the implemented design).
Hope that helps,
Kind Regards,
Florent
Florent
Hi Florent,
Paul
Hi @paul.tutzu,
No, I have no idea of what was the issue in your first try
Florent
I'm having this exact same problem in 2018.1. When I assign a pin to a port vivado unassigns another already assigned pin which is not in conflict and I keep going around in circles.
I encountered the same issue, but it was because I manually entered the PACKAGE_PIN and then pressed enter. Not pressing enter was the solution.
I'm having the same problem in 2018.2.
Is this a bug? @florentw
