jkk@ms3e.dk
Vivado stuck in implementation phase 4.1.1
Vivado (1016.04) implementation sometimes gets stuck in route_design (-directive default) during phase 4.1.1 even though there is no indications on any problems. It never continues after this message:
Phase 4.1.1 Update Timing
Phase 4.1.1 Update Timing | Checksum: 2ed6bd8c0
Time (s): cpu = 00:27:51 ; elapsed = 00:17:09 . Memory (MB): peak = 4908.734 ; gain = 390.227
INFO: [Route 35-416] Intermediate Timing Summary | WNS=0.077 | TNS=0.000 | WHS=-0.163 | THS=-17.992|
Does anyone know what causes this and is there any solution/workaround?
Br. Jacob
jkk@ms3e.dk
Hi Syed,
I couldn't find a proper solution so I rolled back my latest updates and re-implemented which actually solved the problem. I am unsure what caused the problem but the problem went away after re-implementation.
Br. Jacob
jmcclusk
Mentor
Mentor
The THS value of -17.992 indicates you have a lot of hold violations, perhaps many hundreds of them, and the router may be stuck trying to resolve them.   I suggest that you review your clocking structure, especially verifying that you have clock buffers in the right places.   Look in the synthesis log for warnings about this, that may help pinpoint the problem.
syedz
jkk@ms3e.dk,
did you fix hold violation? Are you still seeing the tool hang during routing?
--Syed
jkk@ms3e.dk
Hi Syed,
Br. Jacob
syedz
jkk@ms3e.dk,
Compare the log and utilization report file with and without latest updates which caused an increase in runtime.
--Syed
jkk@ms3e.dk
I unfortunately deleted the log without the latest updates... I'll close the subject.
Thanks for the inputs.
