Vivado unused IOs behavior
Is there a way to configure the behavios of unused IOs in Vivado like in ISE?
In ISE: generate programming file/configuration options
-g UnusedPin Unused IOB Pins (Pull Down, Pull Up, Float)
Best regards,
Christian
Re: Vivado unused IOs behavior
The equivalent Tcl command is:
set_property BITSTREAM.CONFIG.UNUSEDPIN Pullup [current design]
The possible values for the property is Pulldown (default), Pullup and Pullnone.
Hello @graces
I know this is an old thread but I just wanted a clarifications. Does the BITSTREAM.CONFIG.UNUSEDPIN affect the IOBs only during the device's configuration or does it also affect the unused IOBs after configuration and during normal operation?
I would like to know what is the impedance/level on all my unused IOBs but I suspect this parameter is only applicable to configuration time, am I right? If so, what is the actual impendance/level on my unused IOB during normal operation?
Anyone?...
Hi from experience true for 'run time'..  I have ran performed some experiments and that verified this.
@arquer,
Your query must be related or follow up to this old closed thread but I request you to create a new forum thread for better responses.
--Syed
Thanks @egeek .
@syedz, my question IS related to the original thread... so...?
Hi @arquer,
The idea is to create a new thread for your new/follow-up query, as this thread has a solution for it's original post and is resolved - which is like a reference for users with similar issue.
Hence it is a best forum practice in such scenarios to create a new post for your query (link this thread for reference) and thus it might get more response towards a resolution.
prathikm
