pstobbe
Vivado warning: [Constraints 18-5210] No constraints selected for write.
To get used to using vivado for programming my cora z7-10, I wrote a simple program in VHDL. Everything works as it should, but I get the warning: "[Constraints 18-5210] No constraints selected for write." after the sythesis stage. I'm unable to find information on the warning (of a level I can understand, as I'm quite new to using FPGA's).
I do get a possible solution suggested by Vivado:
Resolution: This message can indicate that there are no constraints for the design, or it can indicate that the used_in flags are set such that the constraints are ignored. This later case is used when running synth_design to not write synthesis constraints to the resulting checkpoint. Instead, project constraints are read when the synthesized design is opened.
I have set the constraints I need and they don't seem to cause problems and I don't know how I could implement what is said in the second sentence.
I'm not sure if the warning could cause unexpected behaviour. Any information or help would be greatly appriciated.
thank you in advance!
these lines are in my xdc file:
## PL System Clock
set_property -dict { PACKAGE_PIN H16   IOSTANDARD LVCMOS33 } [get_ports { clk }]; #IO_L13P_T2_MRCC_35 Sch=sysclk
create_clock -add -name sys_clk_pin -period 50.000 -waveform {00.000 25.000} [get_ports { clk }];#set
## RGB LEDs
set_property -dict { PACKAGE_PIN L15   IOSTANDARD LVCMOS33 } [get_ports { blue }]; #IO_L22N_T3_AD7N_35 Sch=led0_b
set_property -dict { PACKAGE_PIN G17   IOSTANDARD LVCMOS33 } [get_ports { green }]; #IO_L16P_T2_35 Sch=led0_g
set_property -dict { PACKAGE_PIN N15   IOSTANDARD LVCMOS33 } [get_ports { red }]; #IO_L21P_T3_DQS_AD14P_35 Sch=led0_r
set_property -dict { PACKAGE_PIN M15   IOSTANDARD LVCMOS33 } [get_ports { debug }]; #IO_L23N_T3_35 Sch=led1_r
## Buttons
set_property -dict { PACKAGE_PIN D20   IOSTANDARD LVCMOS33 } [get_ports { button }]; #IO_L4N_T0_35 Sch=btn[0]
jmedici1
I am also having the same issue with Vivado 2019.1 . I have created the constraints file in the project, set it as the target, and all of my pins names have the correct case. The problem still persists.
Any help would be appreciated.
wimp
I had the same problem. For me it was due to a typo (due to copy-paste from tutorial) in the port name. Carefully compare to the port names used in the top entity and the xdc-file. Check your warnings in the messages tab for: [Common 17-55] 'set_property' expects at least one object. ["constraints.xdc":1]
Hope it helps.
dave_ssp
I have also the same problem I'm using vivado 2019.1.3 please anyone who got better idea
w_alkakhi
Good Evening
I am using vivado 2019.1.3 . I still have the mentioned warning ([Constraints 18-5210] ) . Is there any solution for this warning ?
I am very thankfull for any help.
Repectfully
Wael Alkakhi
rcjhy8
I as well am getting similar error in Vivado 2019.1
I am using Zybo Zynq 7000 development board and am trying to run this tutorial:
http://blog.idv-tech.com/2014/03/22/howto-export-zynq-peripheralsi2c-spi-uart-and-etc-to-pmod-connectors-of-zedboard-using-vivado-2013-4/
I need this for IIC (I2C) for a project I am using. Any help would be appreciated.
Russell
m3atwad
Voyager
Voyager
I am also having the same problem running a modified zedboard example.  I'm using vivado 2019.1
celliott
Hi everyone,
Thanks for bringing this to our attention. There has been a CR filed for it and the message should not trigger in the upcomming release of Vivado (2020.1).
We are hoping to release an Answer Record once the behavior has been verified for the various versions.
Thanks again!
Courtney
Please don’t forget to reply, give kudos, and accept as a solution if you found this helpful!
lindsay
So what should we do in the mean time? Any kind of workaround?
welson1234
I don't know if this answer the problem or not.
2 days ago,i have warning,too.
Then i found i didn't Generation block design.
so i try to Generation block design.
guess what?The warning is gone.
bkeitch
I had the same issue. The problem is that this can be a very misleading error message. It seems if you have ANY errors in your constraints file, Xilinx (Vivado 2019.2) throws away the whole file and the complains you don't have a constraints file set (when in fact you think you do).
SOLUTION carefully check for errors in the constraints file.
drjohnsmith
Its a very annoying bug. That has been there for ages, as this forum witnesses.
Seems xilinx have little interest in it, imho , xilinx tend to use TCL and scripts, so don't notice this or consider it a priority.
 I got the same error message. It was working a night before. Nothing has changed. But I realized IC7, which is situtated at the center of the Basys3 board is getting so warm that you cannot even touch with your finger when the power switch is on. So I thought the board can be damaged due to some reasons. Nevertheless, I checked the pin connections of my servo and sensor, everything is connected well including vcc and ground cables.
marcb
Please refer to the following AR:
https://www.xilinx.com/support/answers/73510.html
As mentioned above, the message has been removed from 2020.1 as it was found confusing.
ashangar
Dear all,
I got the same error during write_bitstream. I found the real source of this problem in my case, maybe it will help to someone.
Looks like end-of-line comments are not allowed in .xdc file.
For example, I has some lines like
set_property PACKAGE_PIN A10 [get_ports {DATA_dn[19]}]    # was DATA[22]
set_property PACKAGE_PIN B10 [get_ports {DATA_dp[19]}]    # was DATA[22]
and bitstream generation fails.
When I removed all end-of-line comments, bitstream is finally created. Good example:
Artem.
@ashangar
End-of-line (aka in-line) comments are allowed in the xdc file.  You just need to end the Tcl command/constraint with a semicolon (;) before you start typing the Tcl comment.
However, be aware that some Vivado tools (eg. the Constraints Wizard) will very rudely strip off your in-line comments and throw them away.  So, be sure to regularly archive/backup your Vivado project.
Cheers, Mark
nickcamel
Same issue as the rest. It used to work, then tonight the problem began and I ended up here.
What I usually do it to "Generate bitstream" and Vivado tells me synth and impl are out of date and asks if those should be run first, I always say yes (without ticking the "don't ask again box".. , what if I one day want vivado to ask ey?)
Anyway, so this time I
manually ran synth -> OK
manually ran impl -> OK
manually ran bitstream -> OK
Try this. (I also toggle the constraints file used in target for synth and impl.. so toggle off.. ok, then toggle on again, ok).
