spilipchuk
Vivado won't implement a component
I am trying to instantiate a component in my design but no matter what I do it seems VIVADO just ignores it completely. It is not in the netlist or on the schematic and the external ports it is associated with are unconnected. I'm stumped as to what is going on. I've used this component before using ISE and had no issues.
Attached is the project. Thank you!
surajc
Hi @spilipchuk
Are you talking about the I2C_MASTER component in your design? I can see that it is present in the synthesized design.
spilipchuk
Yes, the I2C_MASTER component. It is visible in synthesis but removed in the implementation stage. But even in synthesis stage the bidirectional ports (EEPROM_SCL, EEPROM_SDA) are not wired if you look at the schematic.
