Newbie mhmd07
Warning message from NGDBuild
Hi ,
When i ran Translate process (NGDBuild tool) , i got the following warning :
WARNING:NgdBuild:440 - FF primitive
 'apu_fpu_0/apu_fpu_0/gen_apu_fpu_sp_full.netlist/fpu_is_full.exec_sqrt_sqrt_f   lt_pt_op_speed_op.sqrt_op.fp_sqrt_round_logic.rnd2_q_del_ip_reg.regs[11].reg'    has unconnected output pin
I dont have access to HDL code, how can i remove above warning message?
Could anyone please answer my question?
Muhammad abid
Historian
Historian
Re: Warning message from NGDBuild
Connect that output pin to something relevant?
-a
it means some pins of the module are not connected
if these pins are not used in  the design you can igore  the warninigs
