dwisehart
What are the Phys Opt Design options?
What do the various options do?
Explore
AggressiveExplore
AlternateReplication
AggressiveFanoutOpt
AlternateDelayModeling
AddRetime
Default.
Daniel
vijayak
Use the tcl command "phys_opt_design -help" in vivado Tcl console to know more.
* Explore - Run different algorithms in multiple passes of optimization,
including replication for very high fanout nets.
* ExploreWithHoldFix - Run different algorithms in multiple passes of
optimization, including hold violation fixing and replication for very
high fanout nets.
* AggressiveExplore - Similar to Explore but with different optimization
algorithms and more aggressive goals.
* AlternateReplication - Use different algorithms for performing critical
cell replication.
* AggressiveFanoutOpt - Uses different algorithms for fanout-related
optimizations with more aggressive goals.
* AlternateDelayModeling - Performs all optimizations using alternate
algorithms for estimating net delays.
* AddRetime - Performs the default phys_opt_design flow and adds register
re-timing.
* Default - Run phys_opt_design with default settings.
Refer to page 87 of http://www.xilinx.com/support/documentation/sw_manuals/xilinx2013_4/ug904-vivado-implementation.pdf
Thanks,Vijay
vijayak
high fanout nets.
cell replication.
re-timing.
Thanks,Vijay
siktap
These are directives which control teh behavior of the commands. Each implementation command has a set of directives that could be applied to them. These are all explained in the UG904.
Chapter 2 goes over them. Further They is another flexibility given to user which are called strategies. These vary these specific directives for each command like place_Design or phys_opt design. These are described in the appendix solution of the UG.
http://china.xilinx.com/support/documentation/sw_manuals/xilinx2013_4/ug904-vivado-implementation.pdf
yiqi17
Hi After running Phys_opt_design (from tcl script console), I do see the timing is improved, how can I update the bitstream from the new routing? (If I generate the bitstream agian, the timing shown is still the previous worse timing)
dwisehart
This is an old topic and not really the same as your question. Probably better to start a new topic.
