moon5756
What is happening after "Router Completed Successfully"?
Time (s): cpu = 00:12:32 ; elapsed = 00:05:22 . Memory (MB): peak = 5172.734 ; gain = 23.871 ; free physical = 117588 ; free virtual = 138765
INFO: [Route 35-16] Router Completed Successfully
Time (s): cpu = 00:16:34 ; elapsed = 00:09:06 . Memory (MB): peak = 5172.734 ; gain = 23.871 ; free physical = 117589 ; free virtual = 138766
Routing Is Done.
These are the Vivado run log. So basically, the route_design command finished early, but somehow, it takes a while in the end...? Can anyone explain what is happening between "Router Completed Successfully" and "Routing is Done"?
Thanks!
thakurr
Hi @moon5756
Once the routing is done successfully, the router reports an estimated timing summary calculated using actual routing delays in the routed_summary.rpt . Additionally there are also certain kind of reports being generated  such as drc.rpt, methodology.rpt, power report.
All these reports are located in your .runs/impl_1 folder of your project directory.
You can check your runme.log to verify this.
Rohit
Rohit
moon5756
@thakurr
Thanks for the reply!
Is there any way that I can possibly skip the process? I want to finish routing in 5min 22seconds instead of 9 min 6seconds.
Thanks!
thakurr
Hi @moon5756
In project mode this is more under tool control and generated automatically with Vivado runs. However in non-project mode you have full flexibility whether you want to generate these reports or not. This is because non-project mode is user manageable.
Rohit
Rohit
moon5756
@thakurr
Thanks! I am doing with non-project option and looking at route_design section of ug835, but what options would work?
I doubt it's an issue with a report because for some design, the gap I stated is relatively small(30 seconds), but this case it's about 5 minute. The entire log is shown below.
# route_design
Command: route_design
Attempting to get a license for feature 'Implementation' and/or device 'xczu9eg-es2'
INFO: [Common 17-349] Got license for feature 'Implementation' and/or device 'xczu9eg-es2'
INFO: [Common 17-1223] The version limit for your license is '2018.02' and will expire in -28 days. A version limit expiration means that, although you may be able to continue to use the current version of tools or IP with this license, you will not be eligible for any updates or new releases.
Running DRC as a precondition to command route_design
INFO: [DRC 23-27] Running DRC with 8 threads
INFO: [Vivado_Tcl 4-198] DRC finished with 0 Errors
INFO: [Vivado_Tcl 4-199] Please refer to the DRC report (report_drc) for more information.
Starting Routing Task
INFO: [Route 35-254] Multithreading enabled for route_design using a maximum of 8 CPUs
Checksum: PlaceDB: 79aea397 ConstDB: 0 ShapeSum: d456f0d0 RouteDB: 8ba1b830
Phase 1 Build RT Design
Phase 1 Build RT Design | Checksum: 138276f17
Time (s): cpu = 00:02:31 ; elapsed = 00:01:48 . Memory (MB): peak = 5148.863 ; gain = 0.000 ; free physical = 117600 ; free virtual = 138777
Phase 2 Router Initialization
Phase 2.1 Create Timer
Phase 2.1 Create Timer | Checksum: 1b1c1609e
Time (s): cpu = 00:02:42 ; elapsed = 00:01:59 . Memory (MB): peak = 5148.863 ; gain = 0.000 ; free physical = 117600 ; free virtual = 138777
Phase 2.2 Fix Topology Constraints
Phase 2.2 Fix Topology Constraints | Checksum: 1b1c1609e
Time (s): cpu = 00:02:44 ; elapsed = 00:02:01 . Memory (MB): peak = 5148.863 ; gain = 0.000 ; free physical = 117600 ; free virtual = 138777
Phase 2.3 Pre Route Cleanup
Phase 2.3 Pre Route Cleanup | Checksum: fefc4bb0
Time (s): cpu = 00:02:45 ; elapsed = 00:02:02 . Memory (MB): peak = 5148.863 ; gain = 0.000 ; free physical = 117600 ; free virtual = 138777
INFO: [Route 35-445] Local routing congestion detected. At least 247 CLBs have high pin utilization, which can impact runtime and timing closure. Top ten contiguous CLBs with high pin utilization are:
[CLEM_X25Y101 -> CLEM_X25Y90]
[CLEM_X36Y85 -> CLEM_X36Y74]
[CLEM_X10Y245 -> CLEM_X10Y244]
[CLEL_R_X10Y361 -> CLEL_R_X10Y360]
Phase 2.4 Global Clock Net Routing
Number of Nodes with overlaps = 0
Phase 2.4 Global Clock Net Routing | Checksum: 15f329038
Time (s): cpu = 00:02:57 ; elapsed = 00:02:10 . Memory (MB): peak = 5148.863 ; gain = 0.000 ; free physical = 117592 ; free virtual = 138769
Phase 2.5 Update Timing
Phase 2.5 Update Timing | Checksum: 1b2a7c096
Time (s): cpu = 00:06:55 ; elapsed = 00:03:00 . Memory (MB): peak = 5172.734 ; gain = 23.871 ; free physical = 117587 ; free virtual = 138764
INFO: [Route 35-416] Intermediate Timing Summary | WNS=1.085 | TNS=0.000 | WHS=-0.027 | THS=-0.106 |
Phase 2 Router Initialization | Checksum: 24a270541
Time (s): cpu = 00:08:15 ; elapsed = 00:03:20 . Memory (MB): peak = 5172.734 ; gain = 23.871 ; free physical = 117587 ; free virtual = 138764
Phase 3 Initial Routing
Phase 3 Initial Routing | Checksum: 2f434e89f
Time (s): cpu = 00:08:25 ; elapsed = 00:03:23 . Memory (MB): peak = 5172.734 ; gain = 23.871 ; free physical = 117585 ; free virtual = 138763
Phase 4 Rip-up And Reroute
Phase 4.1 Global Iteration 0
Number of Nodes with overlaps = 1264
Number of Nodes with overlaps = 227
Number of Nodes with overlaps = 27
Number of Nodes with overlaps = 4
Phase 4.1.1 Update Timing
Phase 4.1.1 Update Timing | Checksum: 2847c7324
Time (s): cpu = 00:10:47 ; elapsed = 00:04:17 . Memory (MB): peak = 5172.734 ; gain = 23.871 ; free physical = 117587 ; free virtual = 138765
INFO: [Route 35-416] Intermediate Timing Summary | WNS=1.086 | TNS=0.000 | WHS=0.026 | THS=0.000 |
Phase 4.1 Global Iteration 0 | Checksum: 2847c7324
Time (s): cpu = 00:10:48 ; elapsed = 00:04:18 . Memory (MB): peak = 5172.734 ; gain = 23.871 ; free physical = 117588 ; free virtual = 138765
Phase 4 Rip-up And Reroute | Checksum: 2847c7324
Time (s): cpu = 00:10:48 ; elapsed = 00:04:19 . Memory (MB): peak = 5172.734 ; gain = 23.871 ; free physical = 117587 ; free virtual = 138765
Phase 5 Delay and Skew Optimization
Phase 5.1 Delay CleanUp
Phase 5.1 Delay CleanUp | Checksum: 2847c7324
Time (s): cpu = 00:10:52 ; elapsed = 00:04:20 . Memory (MB): peak = 5172.734 ; gain = 23.871 ; free physical = 117588 ; free virtual = 138765
Phase 5.2 Clock Skew Optimization
Phase 5.2 Clock Skew Optimization | Checksum: 2847c7324
Time (s): cpu = 00:10:53 ; elapsed = 00:04:21 . Memory (MB): peak = 5172.734 ; gain = 23.871 ; free physical = 117588 ; free virtual = 138765
Phase 5 Delay and Skew Optimization | Checksum: 2847c7324
Time (s): cpu = 00:10:54 ; elapsed = 00:04:21 . Memory (MB): peak = 5172.734 ; gain = 23.871 ; free physical = 117587 ; free virtual = 138764
Phase 6 Post Hold Fix
Phase 6.1 Hold Fix Iter
Phase 6.1.1 Update Timing
Phase 6.1.1 Update Timing | Checksum: 26ae72bfc
Time (s): cpu = 00:11:46 ; elapsed = 00:04:43 . Memory (MB): peak = 5172.734 ; gain = 23.871 ; free physical = 117587 ; free virtual = 138764
Phase 6.1 Hold Fix Iter | Checksum: 2390ec9f0
Time (s): cpu = 00:11:47 ; elapsed = 00:04:44 . Memory (MB): peak = 5172.734 ; gain = 23.871 ; free physical = 117587 ; free virtual = 138764
Phase 6 Post Hold Fix | Checksum: 2390ec9f0
Time (s): cpu = 00:11:48 ; elapsed = 00:04:44 . Memory (MB): peak = 5172.734 ; gain = 23.871 ; free physical = 117588 ; free virtual = 138765
Phase 7 Route finalize
Router Utilization Summary
Global Vertical Routing Utilization = 0.34249 %
Global Horizontal Routing Utilization = 0.399326 %
Routable Net Status*
*Does not include unroutable nets such as driverless and loadless.
Run report_route_status for detailed report.
Number of Failed Nets = 0
Number of Unrouted Nets = 0
Number of Partially Routed Nets = 0
Number of Node Overlaps = 0
Phase 7 Route finalize | Checksum: 2796779d7
Time (s): cpu = 00:11:58 ; elapsed = 00:04:48 . Memory (MB): peak = 5172.734 ; gain = 23.871 ; free physical = 117589 ; free virtual = 138766
Phase 8 Verifying routed nets
Verification completed successfully
Phase 8 Verifying routed nets | Checksum: 2796779d7
Phase 9 Depositing Routes
Phase 9 Depositing Routes | Checksum: 2796779d7
Time (s): cpu = 00:12:31 ; elapsed = 00:05:21 . Memory (MB): peak = 5172.734 ; gain = 23.871 ; free physical = 117588 ; free virtual = 138765
Phase 10 Post Router Timing
INFO: [Route 35-57] Estimated Timing Summary | WNS=1.086 | TNS=0.000 | WHS=0.026 | THS=0.000 |
INFO: [Route 35-327] The final timing numbers are based on the router estimated timing analysis. For a complete and accurate timing signoff, please run report_timing_summary.
Phase 10 Post Router Timing | Checksum: 2796779d7
Routing Is Done.
INFO: [Common 17-83] Releasing license: Implementation
14 Infos, 0 Warnings, 0 Critical Warnings and 0 Errors encountered.
route_design completed successfully
route_design: Time (s): cpu = 00:18:18 ; elapsed = 00:10:21 . Memory (MB): peak = 5172.734 ; gain = 23.871 ; free physical = 117589 ; free virtual = 138766
# write_checkpoint leaf_0_routed.dcp
thakurr
Hi @moon5756
Thanks for sharing the detailed log, actually i missed that short portion of log you shared before. Sorry for that.
I do also feel that is not a reporting issue as all the reports are generated once routing is successfull.
Between which OS you are using? Can you make sure you use supported OS with Vivado version you are using?
Please share the design or post place dcp to reproduce this at our end.
Rohit
Rohit
moon5756
@thakurr
Hi, I can't share the file in public. Can you send me your email address in a private message so that I can send you the placed.dcp so that you can run route_design? I don't think I can attach a file in private message here, right?
thakurr
Hi @moon5756
Thanks for sharing the post place dcp offline. I ran route_design over it and here is the timing gap between "Router Completed succesfully" and "Routing is done" (FYI i tried in Windows 7, 64 bit).
So at my end also the time gap between the two is some 2 minutes 40 sec which is high than usual seeking the fact that the utilization of the design is normal.
I don't know the what exactly is causing this but  from the WHS value which is 0.016 ns, i can guess that tool is having hard time to fix the hold. What is the WHS value after synthesis?
Rohit
Rohit
syedz
@moon5756,
Any update on this thread? Let us know if you need more information/clarification.
--Syed
moon5756
Hi @syedz,
I tried different approach and this issue is gone. I have been able to exactly figure out what caused this behavior though.
thakurr
Hi @moon5756
Glad to know that your issue is resolved.
Can you please share the solution with community and accept that post as solution? This will help forum  users incurring similar issue in future.
Rohit
Rohit
