hrmt
What's the initial value of the Register in CPLD ?
Hi everybody
i have a  xc2c1287vqg100c cpld, and now i have a question about the initial value of registers in CPLDs?
thanks.
jack.roundhouse
The XC2C128 doesn't have any registers per se. Registers are implemented using a HDL if you need any.
hrmt
@jack.roundhouse
yes my mean is : when describe a RTL by HDL, we have Registers in design and now what is initial value of these registers ?
jack.roundhouse
The registers have an initial value if needed, exactly as needed. You have to define initial value at preset, reset or set conditions.
Here is an example:
process(Clk)
begin
   if(rising_edge(Clk)) then
	   if(sync_reset='1') then
	   	Q <= '0';
	   else
	   	Q <= D;
	   end if;
   end if;
end process;
