diverger
Will Vivado do some 'optimization' when "place I/O ports in an I/O bank"
When do I/O planning, you can use 'place I/O ports in an I/O bank' to place multiple ports in designated bank. But sometimes the ports Vivado chosen is separated far away from each other, even there are free ports next to each other. I wonder if there are some rule when Vivado choosing ports for you? Will Vivado do some 'optimization' when choosing ports location, or it just allocate them randomly?
Tags (2)
marcb
Hi @diverger. The I/O Placers main goal is to find a valid I/O placement. To do this, it must make sure that no I/O compatibility rules are violated, such as conflicting IOSTANDARDs. It also must make sure that global clocks are on clock capable pins, and the I/O logic such as I/ODDR, and I/OSERDES have their I/O placed in package pins that have the required resources for that device.
drjohnsmith
vivado IO auto placement,  seems to work on the basis of spreading the ports out,
Im guessing to minimise interference / ground bounce and  to spread rooting.
Basically, it not of much use to real layout, but useful for a first test of , does it fit.
marcb
diverger
Actually, when create the IO ports, I only set the 'Direction' and 'I/O Standard', and no other limitations (it seems there not so many options in the 'create port' dialog).  Sometimes (if not always), Vivado places the port far away each other, though there exist free pins next to each other.
drjohnsmith
yep
auto placer just spreads the IO around the chip to sites that work.
