Visitor wtl121
XDC constraint
Both the IDDR and the IOB FF are driven only by the IBUF in the same IOB in my design.
MY CODE:
IOBUF iobuf_iodata(.I(iodata_mux),
                   .IO(iodata), //PAD
                   .O(iodata_buf),
                   .T(iodata_out[5]));
ODDR oddr_odata( .Q(iodata_mux), .C(iodata_out[6]), .CE(1), .D1(iodata_out[1]), .D2(iodata_out[3]), .R(0), .S(0));
IDDR iddr_idata( .Q1(iodata_in[0]) .Q2(iodata_in[1]), .C(iodata_out[6]), .CE(1), .D(iodata_buf), .R(0), .S(0));
assign iodata_in[2] = iodata_buf;
always@(clk)
    ss_iodata_in[2:0] <= iodata_in[2:0];
ss_iodata_in[2] be placed in ILOGIC,but i want IDDR to be placed in ILOGIC.
I try to design my XDC constraint file.as follow,
set_property LOC ILOGIC_X1Y497 [get_cells */iddr_odata]
set_property IOB FALSE [get_cells */ss_iodata_in[2]]
But this constraint is not used.
How design my XDC file?
回复: XDC constraint
IDDR is dedicated to be placed in ILOGIC.
How is the cell 'iddr_idata' placed then?
Visitor wtl121
回复: XDC constraint
In my result, vivado implementation failed, and ss_iodata_in[2] be placed in ILOGIC.
回复: XDC constraint
@wtl121
What is the error message in implementation? Can you please share the post-synthesis dcp file?
--Syed
