Participant sjg69
XST crashing when I click 'play'
Whenever I click on the green 'play' icon to try and compile my verilog design targetting an XC9572XL, I get:
lots of stuff...
Design top has been optimized and fit into device XC9572XL-5-TQ100.
ERROR:ProjectMgmt:387 - TOE: ITclInterp::ExecuteCmd gave Tcl result 'can't read "iFileType": no such variable'.
Tcl_ErrnoId: unknown error
Tcl_ErrnoMsg: No error
_cmd: ::xilinx::Dpm::dpm_chTransformExecute dpm_fitterRun $piThisInterface
errorInfo: can't read "iFileType": no such variable
while executing
"if { $iFileType eq "UNKNOWN" } {
continue ; # unknown is just ignored, its probably .txt
("foreach" body line 3)
invoked from within
"foreach sItem $lOutputFileList {
if { ![dpm_parseOutputFile $sItem $iDesign sFile iFileType fileOrigination] } {
if { $iFile..."
(procedure "dpm_chTransformOutput" line 15)
invoked from within
"dpm_chTransformOutput $iTranInst $lOutputFileList"
(procedure "dpm_fitterRun" line 477)
invoked from within
"$sCmd $iTransformInstance $sCmdArgs"
(procedure "dpm_chTransformExecuteEngine" line 100)
invokedTransformExecuteEngine $sFlowProc $iInterface $bRunTransformWithEmptyInputSet "
(procedure "::xilinx::Dpm::dpm_chTransformExecute" line 3)
invoked from within
"::xilinx::Dpm::dpm_chTransformExecute dpm_fitterRun $piThisInterface"
Any hints as to what's going wrong ? There are various warning about ports not being used (which is fair enough, I'm only about halfway through designing it) but it shouldn't crash, should it ?
Simon
Participant sjg69
Re: XST crashing when I click 'play'
Should probably mention that this is using ISE 14.5 (running on XP). The machine has plenty of RAM (16GB) and ISE is the only application installed on it.
Simon
It is not clear from the messages you gave that in which process this error occurred. Can you post more messages before the line "Design top has been optimized and fit into device XC9572XL-5-TQ100." so that we know what process was running at that time.
Vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
Participant sjg69
It was cpldfit.exe, from memory - there was a dialog box that came up asking me if I wanted to report it to Microsoft ... I can check tomorrow and get more log and maybe a screenshot because it reproduces every time.
Participant sjg69
Ok, I've attached 2 images, the first is the warning dialogue when cpldfit.exe crashes, the second is the result of clicking in that dialogue to see more info. The third is the entire log in the console. It's just 'fit' because everything worked up until then.
Cheers
Simon.
Teacher eteam00
Try this solution (which disables Windows SmartHeaps).  It's very simple, and easy to undo.
-- Bob Elkind
SIGNATURE:
Summary:
I'm not sure you'll find much expertise here on CPLD tool issues. You might want to try the CPLD forum as well.
Participant sjg69
Well, I tried the approach suggested by eteam00, but it didn't seem to help me. cpldfit is still running, some 8 hours later, which seems excessive for a design that, according to the last time it did run, only took about 50% of the resources of the device and mapped in ~20 secs.
So I think I'll revert the change.
What caused it was when I expanded the state machine to include some more signals in the always @(...) block. Over the weekend I've re-jigged that anyway, so when I try the new code tomorrow, perhaps it won't be an issue again...
Simon.
